Originally Posted By: RobbS
Originally Posted By: Sixxer
Thanks for the input Robb. I have been trying to use it in more areas. Its great in the transmission, I used it in the power steering and that seems great, and its currently in the diff as well. How do you like the 4.6 cobra? I have thought about picking one up for 5-7k
I use Amsoil in the differential, Mobil 1 automatic transmission fluid in the T5 transmission and power steering sump. Borg warner/Tremec recommend Mobil 1 or Synchromesh for their transmissions, works for me.
-The 4.6 Cobra is wonderful. The modular motor sounds incredible, feels incredible. Theres faster cars out there always but today there is no engine that sounds as sweet as the modular motor in my opinion. Sadly, a dying breed. I am thrilled to have it. I give it love daily.
The 4v has a very distinct exhaust note. It sounds nothing like anything else. Ford tried really hard to get the 2V to sound like the 5.0 and in my opinion its close,but the 4V was its own animal. Ford wasn't trying to re-create anything with the sound of the exhaust,so that meant there was no molestation or any funny tricks. Just a pure sound all its own.
Get a pair of Mac long tubes and a prochamber. Trust me. The sound of that combo is fantastically musical,with an echo and voice that is all its own. The prochamber gives it a deep rumble almost like a big block to be honest,but if you put an x-pipe on them and it the 4V goes from a big block sound to a raspy higher pitch,more like straight pipes on a 283.
The 4.6 4V has incredible potential as an engine. The heads flow great right out of the box,they have the ability to rev into outer space. Stock the 4V drops off at around 7000rpm but just an intake cam change and leave the exhaust cam stock and you can gain 500 useable rpm and 30hp.
The ford purists complain that the 4.6 was anemic however it made great power considering its displacement. They aren't as simple as the Windsor based 302/351 but with some though and a few tricks and those 4.6 engines could really put out.
The first 4V v8s were in the Lincoln's. they had an intake that had both long and short runners,so the engine would make good torque then the baffle would move over for top end hp. But the weight of a Lincoln was too much for such a small displacement motor. Those cars need cubes to offset the weight,in my opinion.
See what you guys did. Start talking mustangs and I run away babbling.
Anyways nice car Robb. Post pics when possible.
