ATF for Kia specifying SP-III ATF?
MA, USA
I have a 2010 Kia Sedona with an automatic transmission. It specs Kia SP-III ATF. It now has 220k miles and I have owned it for the past 30k miles. It runs very well. I want to keep it going. You can not change the ATF filter with out pulling the Transaxle so it has never been done and likely never will. It has a magnetic drain plug that makes draining and filling easy. Many on the Kia forum suggest the Valvoline MaxLife ATF. When you do a drain and fill you get about 50% out. I just did one with the Valvoline MaxLife and I noticed a slightly smoother shifting right a way. After about 1000 miles I noticed when taking my foot off of the gas the transmission sometimes will not clutch out the engine as soon or as well. Does that make sense to folks? I am wondering if the seal conditioners in the Valvoline MaxLife ATF is effecting something? I do not have any leaks but I thought at the mileage and age I am at, it would not hurt and may help going forward. I am thinking of doing another drain and fill with a different ATF. Maybe the Valvoline Full Synthetic Extended Protection? It is more money but it does not have the seal conditioners and it claims to protect better. Another $25 or $35 is nothing in the big picture if it prevents a problem. Heck, $100 more may be well spent money. At the age and mileage , I am reading against doing a flush. Looking for thoughts from the good knowledgeable people here.
p.s. I asked Perplexity "Is SPIV backward compatible?" I am paraphrasing here but It said only if it claims to be on the packaging. Interesting and safe answer. I think my Mail man could have given me that answer. Bar tender or who ever you want to substitute.
Think I would talk to a dealer first. I have gone thru this with a 2014 santa fe and gave up. dealer service only. good luck. Transmission OK at 135K miles so far.
I don;t like multipurpose fluids, so that leaves me out of maxlife world.
At that mileage I would advise against a complete flush. As far as which fluid I don't think it would much matter. I have always used the Max Life in my Hyundai/Kia products without problems. At 220K mileage I suspect something is just wearing out.
Went through this with mine and a couple colleagues older Hyundais. Nothing I tried has made a greater difference than just having fresh fluid. Maxlife, import mv, Castrol import, atf +4. I would try the aisin application specific spIII personally but maxlife is just fine
I too used Maxlife in a 2007 Sportage and it ran great. However this was a few years back before Valvoline added CVT coverage. Can't say how the current brew would work but likely is fine. I don't know if it's the same transmission but I also got right at 50 percent capacity to drain out. You should try 2 more drain and fills with Maxlife then go from there. As an aside Valvoline Import ATF is a hair thicker if you want to go that route.
I have the blue bottle Valvoline Multi Vehicle Import in my son's 2010 Forte. It had the Maxlife red after a 3x flush for a while, maybe I'm imagining but the Multi Vehicle blue I think shifts a bit better, he's at 202k miles.
All the places say the newer lower viscosity versions are backward compatible and fresh of something is best. In another vehicle, '08 CRV, I had choice between the lower viscosity or the slightly higher viscosity. I emailed the company, High Performance Lubricants, and they recommended the higher viscosity as it was closer to the original Z-1 it came with. I went with that and all is well. I applied the same logic to the Forte.
The newer Restore and Protect ATF might be a good idea to help clean up the internals. Also, adding Lubegard Red to what you have now and running it about 2K might help as well.
You bought the car with 190K miles and have done your first D&F at 220K miles. Any idea of the maintenance history and if SP-III has always been used? What was the condition of the fluid that came out? Burnt smelling? You should celebrate that transmission has lasted that long, is the vehicle a 4 cyl or the 3.5L V6? My son's 2010 Santa Fe 3.5 had the transmission go out at 160k and it was serviced every 40-60k miles.
I've had an SP-III vehicle, a 2007 Kia Rondo. I had good luck using Castrol Transmax, it was more similar in viscosity to the SP-III at the time I used it, in the low 7s CST at 100C. Not sure if they still make it. It was available at Walmart in the era that I owned this vehicle.
The Maxlife is more like an LV fluid, I believe below 6CST. I've had issues using Maxlife on a Toyota with shift flares and whatnot. I'm not opposed to using universals, but I'd stick to similar viscosities.
This is actually my second ATF D&F. I did one shortly after I bought it. I used Super Tech ATF that claimed to meet SPIII. It was dark but not burnt. The same with my recent D&F. IT was dark but not a burnt smell. It is a V6. I think it is a 3.8L. The viscosity of the SPIII is a bit higher than the red bottle max life. The Multivehicle import blue bottle viscosity matches closer to the SPIII. I just realized this in the past few days. I may go with the blue moving forward, for that reason. There was only one other owner and he had it serviced regulatory at a quick change oil place. I know he was very good about oil changes. IDK about transmission service. But I would assume he was as these oil change places are aggressive about selling you on these types of services.
I used Idemitsu HK4 on my daughter’s Elantra with 222K miles and questionable previous services. It worked great. Big improvement in shifting.
I’m not a fan of catch all spec fluids. Idemitsu has a SP3 version I believe called just HK. O’Reilly’s usually stocks it. I’d probably try that in your same situation.
I used Valvoline Maxlife (red bottle), Valvoline Import (blue bottle) and Castrol Import MV in my daughters 2008 Elantra...all worked great. I don't think the SP-III spec. is so unique that 'multi vehicle' ATFs will hurt.
OTOH, I stick with Mazda FZ approved (blue fluid) in her Mazda CX-30 (I've done 2 D&R's with Aisin's version) because there is much debate on whether Valvoline Maxlife type replacements would cause issues? I've read on this site that Mazda would deny warranty if the fluid is red on a failed unit?
Warranty issues are always tricky so I would understand in sticking to the OEM factory fill in that case or at least a specific/dedicated SP-III . I hear and read alot about people have good to better experiences using the various Valvoline products. I also recently read about Amsoil ATF. Very expensive but very good reviews. They claim you can doulbe your OCI. In my case I would never do that because I can only change the ATF and not the filter. Only about 50% comes out with a D&F. Also because of its age and having the original filter, I would never do a flush.
One thing people can do to improve transmission life is add an auxiliary cooler. I am surprised no one mentioned that on any of the threads I read here. Especially if you pull/carry a large load or live in a very hot or mountainous area. I do not fit well into any of that. Although it can get into the high 90s here in the summer and maybe once a year I load the van up with 1,000 lbs. for one short trip. Not sure if it will add value to me. Although it could not hurt.
I will add , I decided to go with the Valvoline Foreign multi vehicle (blue). Its viscosity is in line with the SPIII. The Max Life(red) is lighter. I have been noticing the trans has been shifting a bit more problematically and I hope this will make a difference and worth a shot. If not then it is done.
The Idemitsu HK is the ATF that meets SPiii.
