Quote:
One is only draining the oil (more oil than a short hot oil drain) from the pan...More dirty oil in the pan to be drained...less in the engine.
But is the difference significant? A half hour after a hot drain, I doubt there's more than a half-cup of oil left in the engine, if even that.
Quote:
Cold oil flows freely..and with enough current to sweep away particulates that are no longer suspended (if any) in the oil.
Easy for you to say, you live in Huntington Beach, CA. Imagine changing oil in the winter in Chicago. Assuming a typical 5w30, 17cSt @176°F, 168cSt @68°F, 570cSt @32°F.
And if you're taking a sample from the drain stream, you want the oil and contaminants well blended, like after a long drive.
