CHAMP PH 2867 CUT OPEN
In the shop
Off of a 2008 i believe Honda CRV of brothers friend. Has over 200k on it. The date on filter end was january 2017 also as mostly gone when i looked at it. Had it in the basement since last fall. Brother and I did water pump and timing belt (second time it was done btw) spark plugs and leaking crankshaft seal. 4cylinder engine. This work was done around 198k. Brothers friend drove it maybe 1k then i changed oil for him with tough giard 7317 and QSGB 5W20. We used this oil after we did the work stated above. I had like 11 of these filters as work was going to throw them out.
Enjoy the pics.
Originally Posted by blupupher
Solid looking filter.
Aside from the nitrile ADV, looks a lot like a M1 filter.
You are right
Originally Posted by nwjones18
Filter looks great. Don't think its a 2008 as they have a timing chain.
I'm probably wrong on the year. I'll have to ask my brother
Originally Posted by TheLawnRanger
Is this similar to an ACDelco classic (non e-core)?
I honestly dont think so, considering the way the bypass is near the baseplate and AC DELCO Classic has holes in its center tube.
