Originally Posted By: grampi
Originally Posted By: BusyLittleShop
The pros and cons of each...
Lightest weight...
1 belt
2 chain
3 shaft
Best efficiency...
1 belt
2 chain
3 shaft
Lowest maintenance...
1 belt
2 shaft
3 chain
Most expensive...
1 shaft
2 belt
2 chain
Least amount of drive line snatch...
1 belt
2 shaft
3 chain
Biggest vocal following...
1 shaft
2 chain
3 belt
1... belt drives are 5 lb. lighter than chain...
2... belt drives only sap 2% of available engine power and never take more
through it's life... whereas chains start sapping 2% and progressively
sap up to 7% near their end...
3... belts don't need slack and therefore are positive drives whereas
chains need slack and are snatch drives...
So lighter... more power... less snatch is why I went ahead and
converted my VF500F Interceptor into the famous Belt-o-ceptor... plus
the fact Honda said it was impossible... well all it took was 8 months
worth of engineering and machine work plus $1500.00 in parts...
Belt life was good... going 2 times the distance of a chain and
it covered 40K miles without needing any adjustment...
Honda VFR1200 Veefalo $4148.00 / 40 pound shaft system...
The only one I disagree with is maintenance. Shaft drive requires less maintenance than does a belt. Belts need to have the tension adjusted, and they need to be replaced from time to time, which requires the removal of the swingarm. The only thing shaft drive requires is the occasional oil change...
I like that story.
The shaft drive requires less maintenance, only if all is going well.
If it's not then good luck to you.
Belts rarely need to have the belt tension adjusted, and it's not hard nor is it laborious.
Replacement is rather rare. Actually I've known them to go well over 100,000 kms without replacement or a problem with worn components.
The Harley belt system is superb IMO.
The only real weakness with a belt drive system is in the unlikely and rare event of a stone being thrown into between the belt and sprocket, which causes the belt to break and all drive can be lost as a result.
Removal and replacement of the rear axle is the only thing required for a belt change, and is no different to the scope of work required to change a flat/worn tyre which I estimate to take 15-20 minutes tops all going to plan and taking care.
No need to check for lateral play in the trunions.
No oil to change.
No drain plug magnet to thoroughly clean off.
No waste oil to dispose of.
No requirement to replace the drain plug because some idiot who has worked on it previously has used the wrong bit to remove/tighten the drain plug and ruined the socket end.
No components like the rear brake calliper, sensors and rear wheel to remove in order to drain/refill the drive unit with fresh oil, also the time taken to complete the process.
No necessity to disconnect the rear drive and rotate it down in order to drain the unit through the filler hole on earlier models.
Oh yeah, they're good alright.
The occasional oil change hey.
Oh well, it helps to pay my bills.
