- Joined
- May 11, 2023
- Messages
- 6
Thought you guys may be interested and suspect that you prob already know the answers answer, but I sent the following email to the tech department at an Aussie oil manufacturer (Penrite):
Dear Tech Department,
I hope this email finds you well. As a long-time user of Penrite oils, I would like to reach out and seek your insights on a few technical questions regarding 2-stroke oils. Your expertise in the field would be greatly appreciated.
This is the response I got today:
The best I can offer is a summary of the test criteria used to rate 2 stroke motor cycle oils, made available from industry and online sources.
From these you can infer answers to your questions. Please see below image :
See also: https://www.mototribology.com/articles/jaso-explained-part-2-2-stroke .
Thanks for your interest in Penrite.
- When a manufactorer recommends a JASO FD oil for a machine like a motorbike (assuming pre-mix instead of injection), does the FD rating primarily focus on smoke reduction rather than lubrication? From my understanding, even your tech guide (attached - page 23) suggests that lubrication properties appear to be similar, with the additives primarily aimed at reducing smoke emissions to meet environmental standards. In theory, would a JASO FB oil, such as those used by greenkeepers, work as a suitable lubricant for a 2-stroke trail bike?
- Considering that blowers, chainsaws, brush cutters, etc., which typically use JASO FB oil, tend to rev at least as hard, if not harder, than a 2-stroke bike ridden by an average weekend rider in off-road conditions, would the lubrication requirements be similar?
- If a motorbike recommends JASO FD oil, would the choice between mineral-based or full synthetic oil (assuming both meet the JASO FD specification) make a significant difference in terms of engine wear?
