Originally Posted By: badtlc
It sounds like type of tire on the same car can make a difference. Does anyone have any idea what the differences in tire construction would be that would allow this different tread wear at same PSIs?
There is no "one size fits all" answer for "correct" tire pressures.
Not everything you read on the internet is true.
To answer your question:
Tire size; ply rating; Load Rating; LT or P-metric; winter, summer, all-season; highway, all-terrain, off-road; bias-ply, radial or run-flat; etc.; etc.
The point is there are almost an infinite number of variables that affect how higher than recommended tire pressures will work on your particular vehicle.
One thing that would help reduce the confusion would be to cite increased tire pressures as a % above recommended pressure rather than a psi amount. For example, 6 psi in a low-profile highway tire would, probably, show much different results than 6 psi in a large truck tire.
The auto makers invest a lot of research into determining the recommended tire pressures and recommended tire sizes for their new cars. These sizes and pressures, indicated on the door jambs of every new car, can be viewed as the best compromise to meet all design criteria which could include, but are not limited, to the following (and not necessarily in this order)under average use conditions:
- Safety
- Gas mileage
- Ride comfort
- Load carrying ability
- Vehicle handling
- Tire wear
Adjusting the recommended tire pressures, either up or down, will affect the balance of performance criteria recommended by the manufacturer. This isn't necessarily a bad thing. If, for instance, you always traveled with several passengers and cargo, then you might be better off increasing the tire pressure to better handle the increased load. For better gas mileage, you might be better off increasing the recommended pressures in an attempt to decrease rolling resistance. The price you pay, however, is decreased performance in other areas like tire wear, braking performance and handling.
In your case badtlc, it seems you have done all the experimentation necessary to clearly determine that if the tire wear you are currently experiencing with your +6psi pressures is unacceptable, you should clearly reduce your pressures.
Sure, there can be general guidelines for tire pressures, but it impossible to say with any certainty what pressures are ideal for your situation without some specific data. Sounds like you have collected that data, so go ahead and act on it - reduce your pressures.
