Caterham Blend Revisited: Best Modern Synthetic Oil In GDI Engines ?
Originally Posted by Gokhan
To give CATERHAM the credit he deserves, his motivation for his blend was his pursuit to optimize the HTHSV so that his oil pressure would be at the maximum at an RPM he desires, instead of at a lower or higher RPM. He had made the important discovery that the HTHSV governed the oil pressure, not the KV100 as one would naively think, which was a remarkable achievement.
The problem with the available oils is that they are either ILSAC, which have HTHSV less than 3.1 cP, or ACEA, which have HTHSV more than 3.5 cP. He wanted something right in the middle to optimize his oil pressure and he achieved that by mixing an ILSAC oil with an ACEA oil. It was an honest effort.
Thank you for that. I don't question CATERHAM's motives or his effort. What is a problem in my eyes, however, is his pattern of drawing conclusions and making claims that simply aren't supportable given the evidence and standards at hand. Shannow, notably, has plowed that ground deeply and thoroughly already. This situation is further aggravated by his doggedly emotional and occasionally downright hostile defense of the plainly indefensible. EDIT: I should have added that I'm not claiming that everything he posted is incorrect, he did offer some good solid information too.
Like the vast majority of members of this forum, I'm not an engineer of any sort (let alone a chemical/petro engineer), and my goal (beyond the fun of it) is of course to learn something. For that to work at all, you've got to remain teachable (and a bit of humility doesn't hurt either). CATERHAM didn't seem to get that at all.
CATERHAM is a scientist by education. He chose to do insurance for a living. If he hadn't studied science, he wouldn't be able carry out and analyze his ingenious experiments on oil pressure and oil blends.
I don't mix oil because I am a purist. However, mixing oil is OK if you want to have fun with it. You can experiment and do UOAs. There is nothing wrong with that.
Mixing a 0W-20 and 0W-40 will result in a 0W-xx virtually in all cases, as both have very thin synthetic base oils. 0W-40 usually has more VII, which increases the MRV and also the CCS to some degree but you're diluting it; so, in most cases, it will still be a 0W-xx, and even if it barely becomes a 5W-xx, it's no big deal.
Regarding the additives, yes, there can be problems, but I don't expect anything drastic, as we are talking about motor oil vs. motor oil, not motor oil vs. transmission fluid. As an extreme example, if one oil relies entirely on ZDDP and another entirely on friction modifier with no ZDDP to protect against wear, the resultant mix will have only half the ZDDP and half the friction modifier, which may not pass the engine wear test, but again, there won't be anything drastic that would damage your engine and you may not even see more wear in your UOA.
Besides, even the oil companies often fail regarding additive synergy and base-oil interchangeability -- high iron levels in some Mobil 1 oils in the past and high lead levels in Red Line probably have to do with the additive and base-oil synergy and the recent failure of Mobil Delvac to pass the Volvo oxidation test probably has to do with base-oil interchangeability. In each case, these oils would have failed a retest. Oil science is a very gray subject and it's probably more of an art than a science. There is nothing wrong if motor-oil enthusiasts on BITOG and elsewhere want to have fun with mixing different oils to create their own blend.
I agree with you. It's not going to be catastrophic if you mix oils. Most of the SN + oils are using Mg/Ca in very similar ratios so now more than ever it's fine to mix. Where I could potentially see it not being ideal is if for example you take an oil that has a Mg/Ca blend (SN +/D1G2) oil then add in some Redline or M1 0w40 which uses a lot of calcium and ZDP. You're then dealing with a detergent system that may not be balanced correctly with the level of FM's and AW additives. Oils are more alike than different, so in the general sense it's fine. I'm a purist as well and would rather keep the chemistry as similar as possible.
Originally Posted by Triple_Se7en
On the week of November 1st, when I do my winter OCI, I will be mixing four quarts of Castrol Edge Black 0W40 with two quarts of Mobil-1 AFE 0W20 for a 6K run to April 2020.
Been doing this blending stuff for almost 30 years. 1st and last owner of my vehicles and when I drive the badly rusted vehicle to the junkyard 18 years later, there is no engine ticking - no blue smoke at startup and the engine runs / sounds perfect..... about 250/275k later.
So your theory that this viscosity blending stuff is somewhat bad....well..... you are dead wrong about that. I am living proof. I want to be near a 0w33 with this blend and I should be knocking on that door. This summer I will run straight 0W40 in that Colorado 3.5. But not in Michigan's cold winter. This five cylinder engine has been treated delicato by me.
Obviously, it has worked for you, but the experience really only proves these things:
1. You have not reached the ultimate limit of your blends, whatever or wherever that may lie. That's good for you, but nobody (including you) knows when, where or how your mixtures will fail (ALL oils WILL fail -- it's only a question of when). No way to tell with this "protocol."
2. A misunderstanding of the SAE grading system. There's no such thing as an "0w-33" oil. The SAE numbers, of course, represent ranges of viscosities. You can attempt to calculate the viscosity in centiStokes of specific mixture, or you could send a sample to a lab for an actual reading. Then you can say, "the resulting mix tests (or calculates) as x cSt, and therefore would fall within the 30 wt range.
3. You enjoy mixing oils, presumably hoping to derive some benefit from doing so. That's perfectly OK, it's your equipment and money and I really hope it continues to work out for you. Seriously. But I won't be doing it.
Enjoy.
That sums it up nicely. Last I heard there was no such thing as a 0W33, which was the point I was making earlier. Simple math doesn't work with mixing oils and calculating viscosity according to people who know a lot more than most of us here.
Originally Posted by Shannow
Originally Posted by dailydriver
BTW, please do not label me a 'fanboi' of his, as you will notice I am NOT using any sky-high VI/VII additized oils currently, nor any self-formulated 'blends'.
You'll note that I didn't label you anything, nor did I assume that my calling him out technically, and responding to his subsequent aggressiveness and repeatedly calling unto question the even presence of my quals was part of the "pile-on" that you were referring to, as it was simply calling out B$...his responses were untoward, and typically ill-informed (well basically often just made up like another current poster on lubrication "science") and hysterically wrong in the lengthy aggressive responses..
You might recall that there was a little board of fanbois who used to revel every time CLAPTRAPHAM took a swipe at me and call me a bully for calling him out...if you weren't on it, participating, then clearly you weren't one of them.
NOPE, I was NOT one of those who got on your case for using scientific knowledge to prove a given theory/statement/claim is untenable, just as I would not for ANY of the actual tribologists/petrochemical engineers on this site (even though I may vehemently disagree with one of them on most of the other 'forbidden' topics which have nothing to do with tribological matters
I usually disagreed with Caterham for the same reasons Shannow did. His fear of oil being too viscous was in my opinion greatly exaggerated and not backed by science. His responses to those who disagreed with him were vigorous, so I didn't stop telling him that I disagreed.
That aptly describes my position as well.
I am strongly against blends.
For the usual reasons.
The dosage in the additive package is dialed in.
Dosage is the key to everything.
Just like with pharmaceuticals in your body.
Look at the generally accepted limits on moly, for example.
~150ppm... just right.
