StevieC
Ok, I passed 1,000km (600 miles) with the catch can installed and it has caught a fraction more oil than it did in the first 300 miles so I'm not sure why the amount varied over the 600km after the initial oil caught in the first 300. It doesn't appear to be linear even though the driving pattern is about the same.
I will take a picture in another 1,000km (600 miles) now that I put some stainless steel filter material in the baffle cage to hopefully help condense the oil better although the outlet hose is dry so I'm not sure any more oil will be caught.
The inlet hose and top of the catch can were wet with oil as and all the cans internal parts so it is definitely still catching oil. The outlet hose is completely dry.
As the can gets really hot under the hood and because the outlet hose is completely dry I have decided to forgo installing the fuel filter because I'm not sure the media in the filter or the plastic housing of the filter can take the heat as it is rated for cold fuel. I e-mailed the manufacturer and they couldn't tell me whether or not the filter could be used at high temperatures.
I didn't take a picture because the oil caught would look similar to the same amount caught in the first 300km.
I'll be back at 2,000km (1200 miles) with an update.
