We had to get a new beater car earlier this year as our 2001 Toyota Echo died a horrible death via hit and run.
We learned the used car market is horrible in our area, but finally settled on a 2013 Kia Rio with 125,000kms on it.
Being a bitog member I immediately started obsessing on how to get the engine cleaner and running better.
I wont bore with all the little things I did like fluids, sparkplugs, filters, however I did try two new things I had never done before: used a GDI intake cleaner, and installed a catch can.
No pics of the intake cleaner operation. But it went something like this:
I followed the instructions on the can and emptied it into the throttle body with RPMS held at 2,000. Gave it a couple pumps to 3,000 RPM then shut of the engine for an hour. Initially I didn't notice anything as I slowly drove out neighborhood. Then instructions said to do some spirited highway driving and I as soon as I opened her up the engine lost power, nearly stalling, followed by the most heart wrenching sound I can only describe as dropping a handful of marbles into the engine. As the random bits of carbon were chewed up in the cylinders a large white cloud of smoke filled all my mirrors and completely blocked any sight of the road behind me. This went on for about 10 seconds before it cleared up. I drove up and down the highway a couple times then returned home assuming I had completely destroyed the engine, but after a couple oil changes and 10,000kms it seems to be doing fine.
I picked up a simple catch can off amazon, it has some baffling, steel wool and a dip stick! Install was pretty simple I found a bolt on the firewall I could mount the can on keeping it lower than the PCV valve so the hose would not have any high spots for optimal drainage, then the out hose feeds back into the intake.
I've been emptying it every 2,500kms or so.
In the summer it doesn't get a ton, maybe around 20ml of watery oil every 2500kms:
But in the cold winter months (-30c) I get around 50-100ml of milky coffee per 2500kms which smells of gas:
