Both of these fluids meet the specs for my 03 Buick century. It has 193k on the original transmission while the motor was just recently swapped and I want to keep it working for quite a few years to come.
Both fluids are literally 1 dollar difference from each other at Wal-Mart with my employee discount so cost is not much of a factor.
Which would you choose?
I also plan to drain and fill the trans at least 3 or 4 times to ensure I have mostly new fluid inside at the end. Also, how often after the first change do you recommend I drain and fill the fluid and swap the filters with the rest of the changes?
