Castrol Syntec Blend....trick stuff?
Texas & BWI Area
Okay Castrol never ceases to amuse me.
Syntec = grpup III under the guise of being a M1 competitor
German Castrol 0w30/SLX = Wow good stuff
Then they have this Syntec Blend which apparantly produces great numbers over Syntec.
What with this company? *lol*
2nd question...is it perhaps that Syntec Blend happens to be a TRUE blend....4 & 5 groups inside?
Or some kind of great add pack?
Baffles me-
10W-30 Syntec Blend is A5 rated, which means it is good for extended drains. As far as I know, this is the ONLY blend to carry this rating.
I used the last of my Havoline dino stash this weekend. I am switching to Syntec Blend next oil change. $2 / Qt for an A5 oil? You cannot beat that!
I have used the 5w30 in my new dakota since Dec. 29 and will drain it this weekend. It has been through several single digit starts and constant stop and go driving in cold weather. The uoa will only have about 2000 miles on it but so much has been short trips. It will be interesting how the oil has held up and how the wear numbers look. It seems to be a excellent oil.
I ran Syntec Blend for many yrs prior to finding BITOG. Then I got bit by the M1 snake and ran that for alittle while. (2 OCIs)
Back to the Syntec Blend and there I shall stay.
For 3k OCIs I find no rational benefit (at least to me) in running higher dollar synthetic.
Oh, the good used oil analysis here are proof enough for me.
Originally posted by novadude:
10w30 Syntec Blend is A5 rated, which means it is good for extended drains. As far as I know, this is the ONLY blend to carry this rating.
Schaeffer's blends of PAO and top quality conventional oil #701 5w30 and #703 10w30 are rated ACEA A3-02 and A5-02. I presently have 10,000 miles on the 10w30 with an excellent analysis; I'll test again at 12,500.
Ken
[ March 08, 2004, 10:55 PM: Message edited by: Ken2 ]
Everyone needs to realize something: It is IMPOSSIBLE for an oil to be rated both A3 and A5. A5 calls for an oil with a max HT/HS of HS of >3.5. The two specs are MUTUALLY EXCLUSIVE, so one oil can't be both. If Schaeffers is claiming to meet both, then something ain't right.
Originally posted by palmerwmd:
Seems to me since you mentioned 2 oils one would meet A5 and the oteher A3.
Fred...
Nope, if you look at the spec sheets he's linked to, they say that both oils meet A3 and A5.
I should have clarified... I was only talking about the Wal Mart / Parts Store brands.
G-man is right... an oil CANNOT be both A3 and A5. As I understand it, A3 and A5 specs are similar, but the viscosity / HTHS requirements are different.
