It is attractive after all...Thank god no one called it castrol Magnetic this time.
Did an oil change yesterday, with Magnatec 5W30 A3/B4 full synthetic. Yes it does have a unique smell. A mixture between sweet and astringent.And weird thing is,Castrol EDGE doesn’t have that odd aroma like Magnatec has,so there’s definitely something different in Magnatec’s add pack.
So what oil is in the sump? Pennzoil Platinum High Mileage or Magnatec?Loving the Magnatec more and more as the miles get put on the oci!!
*Waves at ZeeOSix and Stude![]()
You got the wrong ZLoving the Magnatec more and more as the miles get put on the oci!!
Haha I always get y'all's screen names mixed up.You got the wrong Z
Maggie,of courseSo what oil is in the sump? Pennzoil Platinum High Mileage or Magnatec?![]()
*Do tell ?Castrol turned it into VII rubbery water with the SP spec![]()
Mrs Maggie,she’s as smooth as the most luxurious imported silk*Do tell ?
I just tried Magnatec 5w20 in my Vibe and I got a 2 mpg increase. 25.8 mpg to be exact. I'd never gotten better than 24 before. All city driving.This is going to sound crazy but I recently put the 0W20 Magnatec in my Honda Accord 3.0 V6. Previous fill was Rotella Gas Truck 0w20 and was in for 5k miles. Prior to the RGT the car had a diet of Pennzoil Platinum or Mobil 1 Extended Performance in the 0W20 viscosity. After 1,000 miles into this oil change, the engine is much quieter..especially when cold. I also have been checking my gas mileage....I've had an increase of about 3mpg on this oil...same driving conditions...now that may be due to gas reformulation back to "summer" grade or something else. The last 2 tanks of gas I've gotten 29 and 27 mpg when usually the car will get 25 or so. I'm amazed...never used Castrol before...only reason I bought it was because it was on sale at Pep Boys when the retail store went out of business. Paid $7.50 for a 5 quart jug. Car currently has 220k on it....still runs really well.
Not badWe get a full synthetic Magnatec 5W30 that carries the Euro ratings of A3/B4 as well as API SN. It’s lined up for my next oil change, as soon as all the rain stops. A full-SAPS, high TBN (>= 10) and high HTHS (>= 3.5 cP) oil, perfect for my port injected car.
Previously I have used the semi-synthetic Magnatec 10W30, also rated SN & A3/B4. It ran so smooth in my car I found myself glancing down when stopped at red lights to make sure my engine was still running. It was still running, I just couldn’t feel it. Almost too smooth, it fazed me a bit.
We also get two other Dexos rated Magnatec 5W30 full synthetics
- Magnatec SUV it’s ACEA C3, API SN/CF, MB 229.51 and Dexos2
- Magnatec DX it’s API SP, ILSAC GF-6 and Dexos1-Gen2 plus Ford M2C946-B1, M2C961-A1, 921-A1.
I‘m interested to do a butt-dyno comparison of the older 10W30 semi-synthetic to the newer 5W30 full synthetic.
ImposterMrs Maggie,she’s as smooth as the most luxurious imported silk![]()
I’ll tell you what, I experienced the same thing when I used it a few years ago for a couple of oil changes. Engine just seemed quieter and smoother. Also had less oil consumption than usual. I liked it, never used it again but I would use it again.I'm not one to normally buy into the "quieter oil" thing, but 5w30 Magnatec seems to have reduced the cold start piston slap on our K24 powered Honda Element. The K24s are known for this because the pistons are short skirted. As the miles have racked up I've experimented with a variety of oils, including Euro Castrol 0w30 and 0W-40, Pennzoil Ultra Platium 10w30. I didn't notice any change. But with 5w30 Magnatec, it sure seems quieter. Also, the used oil analysis I've run have shown very good results.
FWIW,
Scott
According to Castrol's own slick sheets, the new SP formulation has changed dramatically as compared to the older SN+ formulation. The differences stand thus:
Old Castrol Magnatec 5w30 Snip (24 May 2018 Slick Sheet):
New Castrol Magnatec 5w30 Snip (5 Mar 2021 Slick Sheet):
I believe this new formulation is worth a try.
Note they "fixed" my recent gripe here ... its Viscosity, CCS @ -30C.
Its kinematic viscosity @ 100C jumped nicely, and the sulphated ash percentage is reasonable as well.
I wish they would have published the HTHS again. Nevertheless, I'm going to run this again ... for sure.
Best!
Maggie is smooth, yet firmImposter![]()
Oh please cat boy![]()
It reads like a Tom Clancy novel, that's for sure. I couldn't put it down until I got to the end.Whew - trying to fall back asleep and read this whole thread - Whew
Startups are super smooth and idle is absolutely silent on the Magnatec. Cold/cool weather performance is better with Magnatec.
FWIW,
Scott
