You choose what Oil I use!!
No Where
Okay its coming up in a couple weeks for the oil change on the 1999 2.2l Camry. So I am going to let the forums decide what I will use. Can be a mix or none mixed formula. All up to you all. Oil filter will be a MicroGreen. I will do a used oil analysis on the current oil which is PP. Then perform a used oil analysis on the next one
Pennzoil straight 30
Pennzoil 20w-50
Castrol GTX MAGNATEC 5w-20
Castrol GTX MAGNATEC 0w-20
Castrol GTX MAGNATEC 5w30
Havoline (i will have to check which kind)
Pennzoil Platinum High Mileage 5w30
Valvoline VR1 60
Valvoline straight 30
Valvoline 20w-50
Quaker State 10w40
Mobil Super 10w30
Three quarts of the Valvoline 20w50 mixed with two quarts of the 0w20 Magnatec would be my preferred recipe. Plus it uses up some of the thick stuff and isn't boring.
Next oci, 2 quarts of the 60 weight stuff mixed with 5w20 or 0w20 Magnatec. Let's use up that Magnatech first buddy.
Maybe put all our names in a hat and draw the winner. Except for Donald since he didn't say anything.
It's Toyota engine. You could run it on a conventional 10w30 with regular OCIs for another 200k miles! Pick what is available and a good value. I suggest something you can find at walmart in a 5qt jug.
ADD on oil choice LOL.
Pennzoil 20w-50
Valvoline VR1 60
Valvoline 20w-50
Quaker State 10w40
Mobil Super 10w30
That engine would probably run fine on a 30W mix of Hoppes Gun Oil, STP Oil Treatment and Marvel Mystery Oil.
Out of the oils you list I'd put any of the xw30s in your car, but I feel like maxlife would be a better choice an anything else you listed, then Redline above Maxlife.
