in visited my local walmart today, of course their selection (and quantities) of tranny fluid was scarce.
They had no maxlife. Lots of supertech tho.
They had castrol import ATF. the bottle said it meets nissan matic D (what doesn't?) and J but not K.
my friend's 02 Altima with 130k, needed a tranny fluid servicing.. badly. it has never been done before.
As I started late in the day, and putzed around, I figured I'd take a quick side step and just swap the fluid and not deal with the filter (this time).
I didn't want to mess with the pan, let alone look in there!
So I swapped in roughly 9 quarts, and cheated, topped it off with lubegard red.
since walmart didn't have maxlife, I decided to use the Castrol HM ATF, that meets nissanmatic d, j and k!
So far, after 50miles of driving, it shifts a lot smoother than it did.
Next year I promised myself I'd drop the pan.
the subframe is parked right in the middle of the pan, all the bolts are accessible, I think it was just a lazy moment.
I dunno if the Castrom HM ATF will be as good as maxlife, but at the worst, should be pretty darn close!
