Castrol Edge EP 5w-20, 7548 miles, 16 GMC Sierra 6.2L
Edgewood, KY
Code
DATE SAMPLED 	25-Aug-18	19-Dec-17	09-Apr-17
DATE RECEIVED 	06-Sep-18	04-Jan-18	26-Apr-17
DATE REPORTED 	11-Sep-18	10-Jan-18	28-Apr-17
SIF NO.
TIME ON UNIT mi	      33811	26263	18621
TIME ON OIL mi	      7548	7642	7207
OIL BRAND		Castrol	Castrol	Mobil
OIL TYPE		Edge EP	Edge EP	Mobil 1
OIL GRADE		SAE 5W20	SAE 5W20	SAE 0W20
OIL ADDED
FILTER    	    	Changed	Changed	Changed
OIL CHANGED     	Changed	Changed	Changed
WO NUMBER
Metals (ppm)
Iron (Fe)  		24 	20 	37
Chromium (Cr)   	1 	<1 	1
Lead (Pb) 		1 	<1 	<1
Copper (Cu)     	3 	2 	4
Tin (Sn)   	   	1 	<1 	<1
Aluminium (Al)  	7 	6 	3
Nickel (Ni)       	<1 	<1 	<1
Silver (Ag)       	<1 	<1 	<1
Titanium (Ti)    	24 	21 	<1
Vanadium (V)    	<1 	<1 	<1
Contaminants (ppm)
Silicon (Si)       	25 	22 	21
Sodium (Na)     	12 	5 	15
Potassium (K)   	7 	2 	<1
Additives (ppm)
Magnesium (Mg)  	12 	26 	136
Calcium (Ca)    	2104 	1936 	1705
Barium (Ba)     	<1 	<1 	<1
Phosphorus (P)  	540 	623 	671
Zinc (Zn)           	635 	743 	746
Molybdenum (Mo) 	71 	78 	95
Boron (B) 		149 	114 	74
Contaminants
Water (%) 		<0.05 	<0.05 	<0.05
Coolant    	    	No 	No 	No
Physical Tests
Viscosity (cSt 100C) 	7.8 	8.5 	8.0
Physical / Chemical
Base Number (mgKOH/g) 	2.2 	2.6 	2.6
FYI: Had fuel injectors cleaned around the 33,000 miles.
These engines appear to perform well with 20wt oils. My sons 2016 GMC Denali has the 6.2 and uses M1 0-20EP at 10-14K OCIs. The vehicle has 72K on it now and runs great. Only problems he has had is the trans low speed clunk. It's been in the shop 3 times for this. The last time, they pulled the trans, but the clunk is still there, only much less evident. A friend has a 2014 Silverado with 110,000K and also uses M1 0-20EP at 10-12 OCIs and all is well.
Wow, 33,811 miles on the oil! Wait, no, the title was supposed to have 7,548 miles in it. Would have been more interesting at 33k miles for sure. Maybe a moderator can fix that. The high iron may be normal for that engine. Blackstone reports have the very handy Universal Averages for the engine type.
You could try a 5W30. It is what I would use of the vehicle was out of warranty. As a matter of fact I have used it while in warranty. It provides a bit more viscosity reserve.
Kind of what I was thinking....the viscosity on the latest Castrol 5W-20 seems low. Why the drop since the last use of the same oil? Did the fuel injector cleaning cause that?
Code
SIF NO.
OIL ADDED
WO NUMBER
Metals (ppm)
Iron (Fe)          24     20     37
Lead (Pb)         1     <1     <1
Copper (Cu)         3     2     4
Tin (Sn)              1     <1     <1
Contaminants (ppm)
Sodium (Na)         12     5     15
Additives (ppm)
Contaminants
Coolant                No     No     No
Physical Tests
Physical / Chemical
Code
SIF NO.
OIL ADDED
WO NUMBER
Metals (ppm)
Iron (Fe)          24     20     37
Lead (Pb)         1     <1     <1
Copper (Cu)         3     2     4
Tin (Sn)              1     <1     <1
Contaminants (ppm)
Sodium (Na)         12     5     15
Additives (ppm)
Contaminants
Coolant                No     No     No
Physical Tests
Physical / Chemical
I appreciate all of your help fellas. Here is an updated file. Currently 45,000 miles on the truck.
  • 16 Sierra Oil Analysis 5.pdf
Might want to edit that analysis, it has some personal info on it. Looks like the 5w-20s have done better than the 0w-20s, at least based on the iron wear. I would've expected the opposite. What's with the Titanium on those three Castrol samples? Is that an additive they use?
