I thought that was supposed to be about as bad as it got for cast iron, but what do I know?
![[Big Grin]](images/icons/grin.gif)
Shiny, like silver? And it doesn't rust? Wow!
![[Patriot]](/forums/graemlins/patriot.gif)
I always thought that shiny black was the ideal. But heck, if it works for you & you like it that way, why not?
My cleaning procedure: after cooking cornbread, I just wipe out the skillet with a dry paper towel. There's enough vegetable oil left behind to keep it well seasoned. Pretty easy, huh?
If it's too dirty for that, I use hot tap water & a plastic mesh pot scrubber.
Too messy for that? Then put about 1/4" of water in the skillet, heat till steaming & simmering over low heat, then scrape out with a stainless steel spatula. Go outside & toss the water & "leavins", then back to the plastic pot scrubber & hot water, then dry with a paper towel. If it looks really dry after all that, maybe rub in a few drops of vegetable oil.
But remember, no expert here, just how I care for the only good cast iron skillet in my Mom's house. FWIW, it seems to be pretty old, with "Wagner" on the bottom, & looks about 10" to 12" in diameter.
