Moving a washing machine to GF parents place. Fill up just before destination. GF tells them to put 92 in it. 95 is on the filler flap but that dropped off and is under the seat. I've put 92 in it without trouble in the past but I suspect it might now be a bit coked (runs on after switchoff) so I've been sticking to 95.
Trouble restarting and keeping it going for the return journey after only about half an hour stop. Improves after about a klick but still hesitates a couple of times during the 20k or so trip and is definately running rough and down on power (which it didn't have a lot of before) going over hump-backed bridges.
So I'm thinking
1. Back-flush or change the fuel filter.
(There's an abandoned diesel pump with a replacable-element filter holder on nearby farmland which I might salvage but its been flooded many times so may not come off)
(The fuel tank has a drain plug but it doesn't seem possible to do it without getting the fuel dirty, so that'd be a last resort)
2. Vacuum leaks. I have lots of ports around the carb blocked with chopsticks. Maybe I have a loose one. Seal them up with tape/goo and/or upgrade to golf tees.
3. Clean the points.
4. Have a look at the plugs
5. Take all my various improvisations off (Paper towel air prefilter, restriction guage/decoker, lighter choke substitute) These have to come off anyway since the car is due an inspection, assuming I can find the mislaid documents. If I can't that's probably game-over since I doubt I can get it through a re-registration inspection again.
Am I missing anything obvious?
I doubt the 92/95 octane difference is responsible, and there's not much I can do about it anyway unless I drain the tank, which I'd rather avoid if possible. I suppose I could try retarding (or even advancing) the static timing a bit.
So I'm thinking
