Hello,
Some times going to the car after being parked (even not for long), it does not unlock using the fob, you have to use the key and when you use the key only the door you stick the key in unlocks while usually all doors unlock automatically. When you get into the car and turn the ignition car starts normally. This happens like 2-3 times a years so I did not bother with it because if I take it to the mechanic everything would appear to be normal.
Now yesterday and today the same thing happened but the car would not start, you would turn the key and the car would appear dead no sign of life, the dash would not light. To start it you have to turn the key keep it turned for like 10 secs and the car starts. This is a new behavior that just started yesterday this made me wonder so I decided to post here.
Battery and alternator are new and I have also tested them with a battery tester and everything seems OK. Is it immobilizer related ? What could the problem be ? if you want further details let me know.
When this happens radio stations are lost, clock resets, OBDII also resets.
My car is a 2006 Daihatsu Sirion
