Hi Dear Friends.
I have a 2010 Hyundai Sonata with around 350,000 km.
The AC usually starts and cools, but the performance is weak when the car is stopped at red lights or idling. While driving, it works better.
There is also another issue: most of the time, the AC starts cooling normally when I turn it on. However, sometimes it does not start cooling. When that happens, revving the engine may make it start cooling, but not always.
One shop told me the compressor is worn. Another shop said it is very likely the valve on the compressor. (they both connected pressure reading devices during tests. )
Refrigerant level is OK.
I understand that symptoms of a worn compressor and a faulty compressor control valve can overlap. But are there any signs that point more specifically to one of them?
Are there pressure-reading patterns that clearly separate a bad compressor control valve from a physically worn compressor?
