Originally Posted By: kam327
Back in 2001, the VW 1.8T had 170hp. Fast forward to 2013, and it still has 170hp, although the torque is up by 18 lb-ft. The MPG numbers are only slightly better.
According to my sources that engine was rated 170 only in the Passat. It was never more than 150 in the Jetta. So there is a 20hp increase in this application and almost 30 ft-lb torque increase.
And
slightly better fuel economy you say? 2001 Jetta: 20/22/26. 2014 Jetta: 25/29/36
I was speaking of the VAG 1.8T 170hp engine in general, not specific to any particular model. My 2001 A4 had it.
As for the fuel economy, my A4 would get 32 mpg on the hwy easily. And that was the AWD model that was heavier and suffered additional driveline-related mpg losses. A FWD Jetta with that engine could have done better. So yeah, I stand by my "slightly better" comment.
Talk about an apples and oranges comparison. If they stick this new 1.8 in an Audi it could very well be tuned to 220 hp, thereby putting your 2001 Audi to shame. Heck Ford's 1.6 ecoboost puts out nearly 200 hp, also putting your Audi to shame.
And then you go on to compare the 2014 Jetta's EPA ratings to what you achieved in your Audi. Those are non-comparable situations my friend. Your Audi's EPA highway rating, adjusted to the 2008 rating scheme, was 25. So if you were able to maintain 32, kudos to your hypermiling techniques. But you should then be able to achieve well over 40 in today's Jetta with your subdued driving style.
