First oil change on car with a canister filter. The media was twisted and I'm wondering if the canister was on too tight or if the filter doesn't quite fit right or if it's normal.
Also unlike a spin on filter a lot of grit and crud remains behind in the housing. I tried cleaning a lot of it out. Can that grit get back in the engine somehow if I don't clean it out? Is cleaning out the housing something I should always do for a canister set up? Can I use carb cleaner?
