The 1964 Fiat Abarth replica vintage racer I recently bought uses a spin-on filter on top of an adapter. Lines from that adapter lead to a second canister-type filter and, past that, to an oil cooler.
Even when the car has only been shut off for a minute or so, when you restart it 2-3 seconds pass before the engine has oil pressure again. The canister-type filter housing is empty, but I have elements for it.
My take on it is that the empty canister is a big dead space that the pump has to refill each time the engine is restarted.
I'm thinking that even if I put a filter element in the canister I will still have a lot of air / dead space there. I want to keep the remote canister because that's how cars of that era were equipped and it looks correct.
I'm thinking I should do something that fills the dead space in the canister and allows the oil to shunt underneath it from input to outflow port.
Any advice is welcome
Jim
Jim
