Originally Posted By: Garak
I suspect you'd be fine with low sulphur European fuel. If it were here, one might have to cut the OCI a bit.
I did have noticed (at least I think so) that the oil change intervals got closer to each other (less mileage) since I moved from 5W20 to 5W30 Low SAPS oil.
I actually was thinking about moving to oil like Castrol Edge 0W40 or 5W40. Both are API SN/CF certified (as mentioned in the Odyssey handbook), Castrol recommends 0W40 for the 2007 Honda Odyssey EX. But I have read that those oils may not provide proper lubrication when they get hotter and they are heavier as 5W30 which can also cause less lubrication which means higher gas mileage and higher wear and tear of the engine.
