up enough stuff to make the insoluble count register at 0.4 on a UOA?
Reason I ask, is I have looked long and hard for a different kind of oil filter, rather then the OEM Isuzu (by Filtech) filter that I've used for some time now, thinking that the OEM filter isn't filtering very well. But, other filters that I have looked at, don't look as quality built as these Filtech's do.
These suckers are pretty sturdy, easy to put on and off, and I tried to open one, took me a few hours.
The one UOA I have done on this truck consisted of: OEM Isuzu filter and Havoline blend 5w-30. This was the 1st time it had ever seen a Blend oil, which most say, I know, is not much different then a regular oil.
The truck, at 154k miles, has had a life of 10w-30 Havoline dino oil, give or take a few change outs of Chevron dino oil and 3 rounds of Rotella synthetic.
So my question is, "should" I keep looking for a new filter, or is it possible that this blend-based oil loosened particules that would otherwise diminish by continuing use of the new blend and same filter?
I have a motorcraft filter on it, 97 Rodeo, now, but it has caused a slight ticking to return. This truck is not a ticker, only when I've used, in the past, Mobil 1, STP, AC Delco, Fram, Purolator premium, and Napa filters.
Thus you can see my reasoning for being filter picky, and I know many say that it could be that one or two filters may have had a flaw, and I was just unfortunate enough to have grabbed the flawed filters when the rest of you can use them without issue - but I don't see how that's likely.
FWIW - the part# my truck calls for, is 3593A Fram/ST, S2808/STP, or M1-104/Mobil 1
I don't remember the part# for Purolator or Napa Gold.
I'd like to know what you guys would do, would you do another round of Havoline blend & Isuzu filter, or keep looking for a non-ticking filter?
Blackstone said the filtering of my air/oil filter was good, but I didn't like the 0.4 Insoluble count after only 2,770 miles on the UOA.
