I would say so, but I don't understand the need to use the same oil in both cars. Are you buying a drum of bulk 0w20?So I can probably use dexos in the vw
I like those charts but you cannot use them as a comparison tool across specifications.Look at the specs in the Lubrizol tool although I'm not sure these are up to date. This is Dexos 1, Dexos 2 and VW508. It looks like VW508 covers more than either Dexos if I am interpreting the chart correctly. But if warranty is a concern, just keep both oil specs on the shelf.
Bottom right corner. Read the instructions. The chart is not intended to compare Dexos oil to VW specs.Look at the specs in the Lubrizol tool although I'm not sure these are up to date. This is Dexos 1, Dexos 2 and VW508. It looks like VW508 covers more than either Dexos if I am interpreting the chart correctly. But if warranty is a concern, just keep both oil specs on the shelf.
I saw the disclaimer in the chart, but doesn't the chart still illustrate the VW508 spec is more robust than Dexos1? Sorry if this chart is a controversial reference, just thougt it would show which spec was superior.Bottom right corner. Read the instructions. The chart is not intended to compare Dexos oil to VW specs.
No It doesn't. The Ordinate value range may change between spec.I saw the disclaimer in the chart, but doesn't the chart still illustrate the VW508 spec is more robust than Dexos1? Sorry if this chart is a controversial reference, just thougt it would show which spec was superior.
As mentioned previously, for warranty reasons I would suggest getting both oils that meet the required specs.
