Show us a legit document that shows a gasoline API SJ can be safely used in the diesel 6.0L Power Stroke.Interestingly, International for the same engine recommends API CH-4 or API SJ![]()
https://www.ford-trucks.com/forums/...use-in-6-0l-vt365-based-on-outside-temps.htmlShow us a legit document that shows a gasoline API SJ can be safely used in the diesel 6.0L
Now, they did not meet you, so maybe they would change their mind.
You must have meant a "Dual Rated" C/S diesel oil. You made it sound like OR a gasoline API SJ oil could be used. That is obviously not the case. Not sure what you posted b/c all the links in a 19 year old thread are dead. Also, There are only CK-4 based oils on the shelves. No one shops for an old CH-4 oil anymore. Especially, when ford does not recommend that old spec currently. Again, Show us where PPE has passed in all the relevant HD F1 testing if you claim it's "Better" than API C & F1 HDEO testing for OP's engine requirements. Surely, you can show it passed with flying colors?Interestingly, International for the same engine recommends API CH-4 or API SJ![]()
Here's a picture of before & after cleaning of my 6.0L EGR that you say doesn't exist.Again, the engine does not have EGR or catalytic converters.
You still did not answer the question how PPE is appropriate for this engine w/testing standards that meet OP's truck.You still did not answer the question how would PPE harm that engine.
Seriously? What exactly is the topic of your discussion? because it is in the first post:Here's a picture of before & after cleaning of my 6.0L EGR that you say doesn't exist.
https://bobistheoilguy.com/forums/t...-egr-and-intake-manifold.374080/#post-6645269
My EGR and Cat fell off already so I’m not worried about affecting those systems.
You're the one quoting me continuously. For the record. What else do you need to say at this point?Seriously? What exactly is the topic of your discussion? because it is in the first post:
So you didn’t read opening post, you don’t know what is API CF, but here you are.You're the one quoting me continuously. For the record. What else do you need to say at this point?
A3/B4 is applicable to high speed diesel engines in light trucks and cars.So you didn’t read opening post, you don’t know what is API CF, but here you are.
This document may be a bit older (pre 2018?)...the Ferrari approval was removed for Pennzoil Platinum Euro 5w-40 in 2018. Ferrari has since recommended for North America, Pennzoil Platinum Racing 5w-40 and for all other markets, Shell Ultra Helix Racing 5w-40.
https://evolubesupply.com/products/...ing-5-40-0-25-gal-0-95-liter-bottle-550051259 (PDS here)
API SN and SP PPE 5W40 are the same oil.This document may be a bit older (pre 2018?)...the Ferrari approval was removed for Pennzoil Platinum Euro 5w-40 in 2018. Ferrari has since recommended for North America, Pennzoil Platinum Racing 5w-40 and for all other markets, Shell Ultra Helix Racing 5w-40.
Of course it can be used. Would I buy Delvac 5W40? Yes. But if I had 18qt on the shelf, it is going in. Only reason I would not use it if vehicle has DPF, which is not the case here.A3/B4 is applicable to high speed diesel engines in light trucks and cars.
SA is 1.0 to 1.6 and minimum TBN is 10.
I wouldn’t hesitate using an a3/b4 engine oil in my 2011LML or 2018 L5P Duramax.
The oil in topic is currently in my John Deere x320 and my son’s 2013 5.3L SLT.
Diesel engines are also speed rated.
Cape class ships are two stroke cross head low speed engines that operate around 250 rpm.
Locomotives and generators are medium speed engines that operate between 900 and 1,100 rpm.
High speed diesels operate over 1,000 rpm.
They will never recommend oil that is not 100% officially recommended by the manufacturer.Ask Pennzoil. There is a Q/A sponsored by this site going on as I type this. Might not be too late to ask but the thread just closed.
cc: @wwillson
[edit] - Answers posted here:
https://bobistheoilguy.com/forums/t...nd-benefits-of-ilsac-gf-7-q-a-answers.393852/
Hello BITOG Members:
Pennzoil here! This time, we are joined by the American Petroleum Institute (API) to welcome members to another virtual community event and, as always, continue the conversation around some of the automotive industry’s trending topics. In collaboration with API, we invite members to join a Q&A related to motor oil specifications. This month, Pennzoil Technical Scientist and Automotive Lubricant Specialist Sean Nguyen...
- wwillson
- Forum: Passenger Car Motor Oil (PCMO) - Gasoline Vehicles
