Originally Posted By: Gary Allan
Ah ..I see, since 5w-20 is out of the question ...perhaps going to 0w-40 can offer "change".
Just kidding. Not much will happen either way going either way.
Yes,
btw- the MZ series of engines is approved for 5w-20 oil.
I believe the MZ series of engines that are approved for 5w-20 oil STARTS with model year 2006.
*None* of the Toyota motors made before 2006 are approved.
As least that is what the TSB I have states;
Is this not the latest TSB?
Take care, bill
No ..it certifies ZERO-W-20 for the 2006 my.
It's a little hard to apply the spec to the 2006 JZ engine if you believe that's the way to read this document.
Toyota JZ engine
2JZ-GTE
Manufacturer Toyota Motor Corporation
Production: 1990–2005
Predecessor: Toyota M engine
That is, all the series mention up top, regardless of m/y are good for 5w-20.
But if you look it says Applicable vehicles. 2006-2007. Not before. (the later 2007 and 2008 they had updated the manual)
Then at the bottom it states;
Note: DO NOT use these (being both 0w-20 and 5w-20) in engines other than above. blah blah IN ENGINES WITH OLDER DESIGNS.
I called Toyota when this came out since my 1ZZFE is on the list(but installed in a MY 2005) and they said to follow the manual since the TSB was for ONLY 2006 and newer. If I ran 5w-20 I could run into problems with the warranty.
(They did make some changes in the 2006 1ZZFE which incl increasing the oil cap almost .5 quart)
The OP does not have to worry about warranty, but I have not seen where his motor is back spec'd for the 5w-20.
Also, I doubt running a 5w-20 would hurt it, I'm just wondering where is the TSB that says older motors can run it?
The JZ motor ended in 2005 but there may be some installed in MY 2006 vehicles?
My 1ZZFE was built early 2004 and it is in a 2005....
Thanks Gary, Bill
