They posted this as a caution based on viscosity of oil which was 11.4. TBN was 9.3 Frankly, am dissapointed in this oil.
OIL CHANGED with 3000 mils on it. Motor had 11500K.
OIL GRADE 10W40 motorcycle oil
FILTER Not Applicable
Amsoil
LAB NO. 42020248818
OIL ADDED: 1/2 pint
SIF NO. 10683285
WO NUMBER
Metals (ppm)
Iron (Fe) 26
Chromium (Cr) Lead (Pb) 1
Copper (Cu) 8
Tin (Sn) 1
Aluminium (Al) 13
Nickel (Ni) 2
Silver (Ag) Titanium (Ti) Vanadium (V) Contaminants (ppm)
Silicon (Si) 4
Sodium (Na) 6
Potassium (K) Coolant No
Additives (ppm)
Magnesium (Mg) 14
Calcium (Ca) 3284
Barium (Ba) Phosphorus (P) 1206
Zinc (Zn) 1461
Molybdenum (Mo) 43
Boron (B) 7
Contaminants
Water (%) Physical Tests
Viscosity (cSt 100C) 11.4
Physical / Chemical
Base Number (mgKOH/g) 9.3
UIN: 01C978A
OIL ANALYSIS REPORT
Gasoline Engine
Unit No. Can AM Trike
Comment:
Engine wear rates appear satisfactory for first sample.
Silicon level (dirt/sealant material) satisfactory. Water
content acceptable. Viscosity low for specified oil grade.
Action: Resample next service interval to monitor and
establish wear trend. Please confirm grade of oil used in
this component.
Amsoil
LAB NO. 42020248818
OIL ADDED: 1/2 pint
SIF NO. 10683285
WO NUMBER
Metals (ppm)
Iron (Fe) 26
Copper (Cu) 8
Tin (Sn) 1
Aluminium (Al) 13
Nickel (Ni) 2
Silicon (Si) 4
Sodium (Na) 6
Additives (ppm)
Magnesium (Mg) 14
Calcium (Ca) 3284
Zinc (Zn) 1461
Molybdenum (Mo) 43
Boron (B) 7
Contaminants
Physical / Chemical
UIN: 01C978A
OIL ANALYSIS REPORT
Gasoline Engine
Comment:
this component.
