Caliper pin rubber vs steel
Hi guys,
Replacing the second caliper pin in the Outback front calipers.
The kit came with two pins.....one with a rubber sleeve and one thats solid steel.
Its odd because both pins have the rubber sleeve.
Can I use them interchangeably? The steel pin fits with no slop and is the same diameter at the tip.
I use Sil-glide for anything caliper related.
Thanks
Ryan
On my Hyundai Accent one has two rubber bushings and the other none. The one with none goes in the bottom.
Thanks for the reply,
Ahhh, well thats good, because thats where it went!
It is strange that a rubber pin came out....very odd
On my Accent I've had it on both top and bottom but the parts drawing show the rubber bushings on top.
