My OCI formula: when the voices tell me to. Or at least a majority of them...
Hard no on that rule of thumb. The gas tank size is an independent variable.oil change every 10th tank of fuel....
Ehhhhh ... Why "200 / 4"? Because "50" was too easy?
There is actually a name for this - "illusion of precision".
If you make it more complex it appears to be more believable, like someone did extra work figuring it out. Rather than just a random number like "50"
Why would MPG matter for OCI? Unless you have a diluter which is an entirely different issue?
It's because we calculate fuel economy in miles per gallon, not miles per quart, and we describe oil pan capacity in quarts. However if you know your oil pan capacity in gallons, then you can save yourself that little bit of arithmetic.Makes people feel special and they can proclaim "yeah, I used a complex mathematical formula consisting of multiple variables that optimally calculates my oil change interval requirements".![]()
I didn't say it wasn't capable of doing 5K intervals long term, full synthetic is simply superior at it and in regards to deposits, varnish, oxidation, sludge, oil breakdown even extreme temperatures this is just an undeniable fact.
Run what you want.
This video is a good example (Conventional is Synthetic Blend)
My GM and Honda oil life monitors have never failed me. The engineers did a great job coming up with the algorithms there. It has saved me a lot of money in oil because I have been able to go much longer than 5k oil changes in both.My formula has never failed: OCI = 5,000.
It is contrived. Every calculation on this board with this formula is approximately 5K miles.And why are the number so nice and round? Why not 215? Or 187?
I totally agree that the volume of motor oil an engine holds, should be a consideration in OCI. Diesel trucks have used large volumes of motor oil to hold soot in suspension, and lengthen the OCI.
But the 200 and 4 just seem to be contrived.
I don’t think this is a good example. That’s a tiny turbo engine in a midsize suv going OLM intervals (likely 10k) on vwb. Surely a port injected Toyota engine on 5k is much easier on oil.
I totally agree with this. A seen the UOA of a friend who installed a bigger oil pan on his GR86 with track duty. Exactly as one would expect, his peak oil temps decreased considerably (since not the whole oil can hold more heat per temperature), and it sheared considerably less, even slower than mere proportional increase would suggest, i would speculate thanks to the more stable temperature. Needless to say, now there is more oil to dilute contaminants.And why are the number so nice and round? Why not 215? Or 187?
It helps with actual mechanical shear?I totally agree with this. A seen the UOA of a friend who installed a bigger oil pan on his GR86 with track duty. Exactly as one would expect, his peak oil temps decreased considerably (since not the whole oil can hold more heat per temperature), and it sheared considerably less, even slower than mere proportional increase would suggest, i would speculate thanks to the more stable temperature. Needless to say, now there is more oil to dilute contaminants.
Though on a car that tackles short city driving would not probably be benefitted from it as now the car would be spending more time with cold oil
You didn't look at the formula correctly.
I should have done it this way (qts x 200) / (4 x mpg) = OK?
Maybe. But if the thermal management is working its not working the oil any harder?
How about a belt vs chain (higher shear). How about DI vs MPI. Why is average oil temp not in the formula? Does it have an oil cooler or not?
Seems like you would be better off to simply follow your manual.
Just in: look what the forum favourite has to say about mpg and oil changes.
I have the video start right at the relevant quote
Lol, your posts always crack me up. Of course you know very well that oil shears faster if it is cold, and its rock stable if it is hotIt helps with actual mechanical shear?
Yeah yours crack me up too.Lol, your posts always crack me up. Of course you know very well that oil shears faster if it is cold, and its rock stable if it is hot
Or rather still believing that temperature can effect the speed of chemical reactionsYeah yours crack me up too.
Still confused about shear heating in a bearing and permanent shear loss due to VM cleaving I see.
"Tend" is the key word. Cars are not built to a specific tanks per mile specification. Some go 180 miles on s tank, some go 600 miles, and that holds true for big vehicles, little vehicles, old, new, whatever. Likewise, the amount of oil in the sump varies on a lot of factors, beyond needing a certain amount of oil to suspend particles and deliver lube, conduct heat, supply additives over a period of time. I would allow that sometimes sump capacity get small as engines get smaller, have fewer cylinders. I'd also suggest that you can insert a Chinese Wall between DI and non-DI engines. Beyond that, there are outlying engines that probably have much higher or lower sump capacities that they might seem to need, like older Jags, Porsches, Subarus, big block V8s and others. Enough pieces are moving that it adds up to a sizable issue using sump capacity in a rule to apply across the board.is it really? the vehicles with large tanks tend to have big engines with big oil sumps
I too have placed faith in the Honda monitors. My last GM car was a 1976 Chevette, so no experience. I do think suggesting that the Honda OLM's are driven by much of an algorithm is generous. I find that they are entirely predictable, more or less driven by mileage, and very hard to parse. For example, in one Honda we currently have, the monitor goes from 100% to 90% in 300 or so miles. Then, every remaining 10% increment gives you 750 or 800 miles. You might think that that increment would increase with highway mileage, but it doesn't. Still, no complaints. I change that oil usually at about 20-30%, somewhere a little over 6,000 miles, but could not see anyone getting in much trouble following the OLM. Just not thinking that there is much going on in the OLM's "brain."My GM and Honda oil life monitors have never failed me. The engineers did a great job coming up with the algorithms there. It has saved me a lot of money in oil because I have been able to go much longer than 5k oil changes in both.
