Nothing bad happened so that is good, but I figured I could post this and save some of you a little $$ and time.
I read in a post a whiole back where msparks was going to have a machine shop drill a hole through a drain plug and then tap one end of it so that he could route his bypass filter return line through it. This saved him from having to drill a hole anywhere else on his engine.
I thought this was a grand idea, esp since my valve covers are plastic and I have no desire to put metal shavings into my oil pan! I know...drop the pan first, right? WRONG!! I have to remove the engine to do it!!! Serious.
Anyway, I liked this idea so I went out and bought a replacement plug and brought it to a machinist I know. Guess what? The **** things are made out of the crappiest metal on Earth! It drill really easy because of this so that was good. What was bad is it wouldn't hold the threads. Every time he would back the tap out to break the metal free, the threads would come out as well! He quickly remedied this problem. However, he installed the fitting just fine but when he removed it so that I could put the lines together all of the threads came out!!!!
So, now I'm on the lookout for a bolt that is actually steel. One problem though...and maybe you guys can help. I can't find a 14mm x 1.5mm bolt ANYWHERE!!!!! The 14mm is easy. Finding it in 1.5 pitch is the tough part.
Anyway, just figured I'd want to warn anyone who was thinking of trying this.
Mikie
Mikie
