I have been musing the Motorguard install in my 02 F150 and upon reviewing/searching the threads noticed RalphPWood mentioned "On some brands of TP filters I have put air fittings in the tops and pushed the oil out with an air pump".Link To Thread
I have the greatest amount of space available underneath the truck along the frame rails and would consider installion of the MG there. Of course filter change mess is the issue if I can not evacuate the oil from the MG placed below the actual permacool adapter oil filter adapter. The MG casing does have the cast boss on the filter to be tapped.
Ralph and All
What do you think ? Has anyone ever seen the air fitting install on the MG ? What type of "air fitting" to install that would work with oil ?
Thanks
Ralph and All
Thanks
