OK, I expect to get some flack, but for what it is worth, here goes.
I recently bought from Rockauto, a selection of filters that will be used for short OCI's and on lawn mowers.
The size I required were all to be the equivalant of a Fram PH 3614.
These are all 'lower priced' not 'high end' filters, but all appear OK to me and are at least as good as I am likely to find locally around here.
None have silicone ADV's, all have coil spring bypass valves.
I DID NOT TAKE PICTURES
This is a non distructive review (I do not want to cut my filters open) My review is purely subjective, I peer down through the outlet hole with the aid of a penlight, I say what I see.
Weights are taken on a kitchen scale, good + - 5 grams.
Prime Guard POF241, $1.32, Made in China, weight: 225g, core is spiral wound perforated metal, pleats look close and even.
AC Delco PF13, $1.69, Made in USA, weight 235g, plastic cage core, filter pleats very un-even, filter element is shorter than others, strange double layer base plate of thin steel.
Filter body larger in diamiter than the others.
FVP R1348, $1.32, Made in China, weight 235g, spiral wound perforated core, pleats appear even.
This filter 'appeared' marginally better than most of the others.
Premium Guard PG241, $1.32, Made in Korea, 230g, spiral wound perforated core, pleats appear even.
Proto PO241, $1.32, Made in China, 225g, spiral wound perforated core, pleats appear a little un-even.
WIX 51348
(Car Quest), $$2.23, Made in USA, 220g, perforated metal core with vertical seam,
Pleats appear even, filter element very short, by-pass valve appears lopsided.
Visually, the filter with the worst in 'fit and finish'
All the Asian filters were packaged with an additional plastic cover on the base plate.
WIX 51348
