- Joined
- Sep 28, 2002
- Messages
- 39,799
Well ..so much for grenading your engine with low visc oil. L@@K at all the bearing wear
If not for volatility issues (or so Bruce tells me) I could have gone even lower as far as seizure protection. I still can't get below just under 40 psi at hot idle. Now some of the rubbing surfaces may be shedding a tad. I imagine that my distributor gear is the Cu and the Fe from the timing chain ..but neither are anything to get excited about.
Still waiting on the read from Terry. Fuel plagued this run due to shorter trip useage during daughter being home for the summer and problems with her hand me down Taurus. Normally I'd have my wife drive this jeep since it gives (relatively) excellent fuel economy using this oil compared to RTS 5w-40. Essentially there is 1 mpg difference in EPA ratings between a 4.0 5speed and a 2.5 auto..but effectively they both round out to about 18+/- in my wife's usage. The difference being that you can hardly get the 4.0 to go below 18+/- ..while you can get the 2.5 into V8 range if you short trip it too much. Current short trip mileage is from 16.5-17.5. My daughter yielded over 23mpg on a longer run to visit a friend in Lancaster county. Even with a couple of warm up events before filling up.. this is amazing economy for this engine. I took a long trip to western PA and got the typical 17.5 at higher speeds (flow of traffic 70-75mph with brief bouts of 80mph). I matched that figure with drafting and keeping it to 65mph on the return trip.
I unsure what I'm going to do with this. I have enough stock to change it out and do a winter run with the wife being the primary driver.
Since this is hard to see (I didn't do something right), here's the data:
Any elements missing were zero across all three.
miles on oil/mileage
2.5k-73k/4.8k-70.5k/9.6k-65.5k
Oil
0w-10 MolyFree Stealth Formula/0w-20 LITE/RTS 5w-40
Fe 12/41/78
Cu 16/11/15
Tin 0/14/0
Pb 0/0/1
Chrome 1/2/4
Nickel 0/2/4
Alum 3/10/9
Cal 2765/2641/2482
Mag 21/43/27
Zinc 1777/1507/1352
Phos 1233/1507/1353
Molyb 275/1698/19
Silicon 28/26/24
Sodium 16/34/22
Boron 15/3/1
40C 22.0/48.8/117.6
100C 4.6/7.5/15.5
TAN 2.29/3.81/6.02
FLASH 270/280/415
OXI 42/55/48
NIT 9/14/20
KF H2O 1063/517/1146
TBN 6.1/3.5/2.8
FUEL 1.73/1.64/0.03
GLYCOL 0/0/0
Sulfate byproducts: 42/50/?
VOA via Bruce's lab. He's got a sample too ..so we can account for lab variance.
Vis @ 40 23.9
Vis @ 100 4.9
VI 132
No VII - GPIII and PAO
ZN 1185
P 1629
CA 2826
Barium 165
Mag 14
Sodium 3
Boron 31
TBN D-2896 10.6
Stealth Polymer @ 8%wt
SL system with the SM AO and FM added
NOACK around 6%
Tin
copper
Aluminium
etc all
Oil
Fe 12/41/78
Cu 16/11/15
Tin 0/14/0
Pb 0/0/1
Chrome 1/2/4
Nickel 0/2/4
Alum 3/10/9
Cal 2765/2641/2482
Mag 21/43/27
Zinc 1777/1507/1352
Phos 1233/1507/1353
Molyb 275/1698/19
Silicon 28/26/24
Sodium 16/34/22
Boron 15/3/1
40C 22.0/48.8/117.6
100C 4.6/7.5/15.5
TAN 2.29/3.81/6.02
FLASH 270/280/415
OXI 42/55/48
NIT 9/14/20
TBN 6.1/3.5/2.8
FUEL 1.73/1.64/0.03
GLYCOL 0/0/0
Vis @ 40 23.9
Vis @ 100 4.9
VI 132
ZN 1185
P 1629
CA 2826
Barium 165
Mag 14
Sodium 3
Boron 31
TBN D-2896 10.6
NOACK around 6%
Tin
copper
Aluminium
etc all
