2017 Ford Expy 3.5L EB 5000mi Edge 0w40 Iron dropped
MA
Hi All, My last UOA had a sudden spike in iron which seems to have dropped back off. Fuel is still high due to my wife's addiction to the remote start (it's been cold here). I also forgot to mention last time that she switched to 87 octane for the winter, which may not be burning completely? Previous UOA HERE
Code
COMMENT: We're pleased to report a solid drop in iron this time around. Sure, the shorter oil change
interval probably helped with that a bit, but there's also been good improvement from a ppm/mile
standpoint, so steel wear really is better than before. Fuel dilution is really the only sticking point in this
report, and 3.0% is a fair amount of fuel. It didn't cause the viscosity to test below grade, though, nor did it
seem to bother the engine's wearing parts. Maybe it's just a fluke and will improve next time. The TBN is
strong, but we'd stay at about 5,000 miles to watch fuel.
MAKE/MODEL:	2017 Expedition	3.5L EcoBoost
OIL		Edge 0w-40	Edge 0w-40	Ford 5w-20?	Ford Factory
MILES IN USE	4963		5500		5148			1338
MILES		16946		11983		6486			1338
SAMPLE TAKEN	1/6/2019	6/10/2018	9/24/2017	     4/14/17
ALUMINUM	5		6		7			15
CHROMIUM	1		2		1			1
IRON		32		59		22			27
COPPER		12		19		30			100
LEAD		0		2		0			1
TIN		0		0		0			0
MOLYBDENUM	60		6		26			70
NICKEL		1		1		0			0
MANGANESE	6		10		7			18
SILVER		0		0		0			0
TITANIUM	6		36		0			0
POTASSIUM	3		3		2			11
BORON		123		40		80			165
SILICON		16		22		32			261
SODIUM		6		6		9			9
CALCIUM		2764		2176		1895			1728
MAGNESIUM	15		12		9			9
PHOSPHORUS	849		790		704			640
ZINC		947		897		761			659
BARIUM		0		2		14			1
SUS VIS 210?F	60.9		59.1		54.8			49.6
cSt @ 212?F	10.47		9.96		8.70			7.14
FLASHPOINT F	325		350		375			355
Fuel%		3.0		1.8		<0.5			1.0
Antifreeze%	0.0		0.0		0.0			0
WATER%		0.0		0.0		0.0			0
INSOLUBLES	0.1		0.2		0.3			0.2
TBN		4.6		3.0		3.6			3.8
ON, Canada eh?
Could have been something stuck in one of the bearings. It's still a relatively new engine so I wouldn't worry and certainly not at 59ppm. This is why trending is important. Had you only had this one report with 59ppm it might be alarming. I wouldn't trust the fuel numbers because they aren't actually measured but interpreted. (Looks like a Blackstone UOA judging by the comments) Maybe send a sample to another lab for your next report to see the actual fuel numbers? Colder weather will always be the worst because engines run richer in the colder weather.
NE,Ohio
IMO blackstone's fuel is always low. might have been 5% or more. Probably the remote starting contributed to that.
The land of USA-made Subies!
Those are pretty significant differences between the two "Castrol 0W40". OP, don't take this the wrong way, but did you personally do the oil change, with a sealed jug? The big differences between moly & boron, the higher viscosity yet higher fuel dilution, the higher TBN yet higher fuel dilution.... they just don't seem to make sense. But, your iron number is down significantly. That's always a good thing!
Waco, TX
No. "Flashpoint" and "Reid Vapor pressure" determines how easily fuel burns in cold weather "octane" doesn't have any effect whatsoever on how completely fuel burns.
89Rustang
MA
Yes, I did it, but it may have been the old formula. I have a lot of stock but they are/were all sealed. Sorry for the confusion.
89Rustang
MA
Originally Posted by Bjornviken
Never seen this castrol edge 0w-40 formula
Looks like I either mixed or used old stock as I did in my other vehicle, which you can see HERE I only have Edge 0w-40 in my stock, all bought new/sealed.
Suomi
Is it some new version of the castrol? when it have moly and boron and very little TI. Or have i missed someting...
89Rustang
MA
it is either this stuff or the stuff I got at Wally's Order detailsOrdered on August 18, 2018 (5 items) Castrol 03101 EDGE 0W-40 A3/B4 Advanced Full Synthetic Motor Oil, 5 quart, 1 pack Castrol Sold by: Amazon.com Services, Inc. Order detailsOrdered on August 18, 2017 (1 item) Castrol 03101 EDGE 0W-40 A3/B4 Full Synthetic Motor Oil, 5 quart, 1 pack Castrol Sold by: Amazon.com LLC Order detailsOrdered on May 30, 2016 (8 items) Castrol 03101 EDGE 0W-40 Synthetic Motor Oil - 5 Quart Castrol Sold by: Amazon.com LLC
