Brown Tires
CA
First off, I fully recognize that “brown” tires are a normal condition that does not need to be resolved.
These tires were installed two months ago. This “browning issue” appeared immediately after I cleaned the tires and wheels using a non-acid wheel cleaner. Prior to this, the tires had a perfectly normal appearance. I have never experienced this “browning issue” with other Michelin tires, but also, this is the first Michelin light-truck tire I have owned.
What happened?
Those aren't bad. Spray them with Stoner's Tarminator to clean. Then Meguiars Hot Shine or something better for shine/protection.
Odd. I might try another tire cleaner or degreaser with a stiff brush to see if that helps. Otherwise the only option probably is to go over it with a tire dressing that will cover it.
You allowed waxes and other chemicals (oils, antioxidants, residual curing agents, etc) in the tire to come to the surface after wiping away a surface layer.
Perhaps I’d become colorblind because I don’t see much brown tinge on the tire from my M1 iPad. Are use S100 Total Cycle cleaner on my tires and wheels, and it does a good job of cleaning off crud. It’s biodegradable so I don’t have to worry about damaging the tire. 🤷‍♂️
I have the same tires. Never seen that.
But then, I only clean the wheels. I spend zero effort cleaning tires. Inspecting, checking inflation, rotating, sure, just not cleaning.
I did not extend very much effort into cleaning the tires - I merely sprayed a small amount of the wheel cleaner onto the tire, then gave them a very quick pass with the soft wheel brush that I was using. So, I was quite surprised to find this outcome.
I put these tires on in December.
They started getting brown 4-5 months after. I washed the truck in May, it went away for a couple days and then came back. I also did not spend a lot of time washing the tires, wheels yes, tires no. I don't even recall running a brush over them, just whatever drippage from the body and wheels.
I did get a tire protectant for the next time I wash it to try and keep it from happening. I'm not a fan of glossy tire sprays.
