Broken Wheel Studs
Winnipeg MB CA
When cycling or on foot, I often stop to pick up nuts, bolts, and washers.
This morning I found these two only a few hundred metres apart, but fortunately it looks like they're off different cars.
The shorter one at the bottom has part of the sheared-off stud inside.
I wonder if the top one is an intact stud off a European car.
I would expect temperature changes to be the bigger issue, the metal clamped by the stud and nut expands when hot (aluminum more than steel) and if the sud doesn't expand the same, the stress increases, eventually fatigueing and breaking the stud. Overtightening doesn't help.
