MolaKule
Staff member
And I always say that the used oil analyis is not for the oil, but for the engine. It's good to know how the engine is trending with a particular oil.
I was in that position 30 years ago with my brand new shiny '69 Camaro. I am even more meticulous now with my vehicles. But I honestly believe and based on what I have seen in my working career with syns that changing at the upper recommended limit with syn is the way to go. Also I can (and do) spend more time actually cleaning my car and inspecting without going through the dirty oil thing. Waaaaaait a minute!!!!! I said earlier its a waste of time trying to convert people to that mode!!quote:
Originally posted by Dominic:
Well - the way I drive, no oil I have ever ran ever looked/smelled/felt/tastedlike new oil when at the 3K mark. It is a $15 comfort for me to change it at 2,000-3,000 miles fully knowing I'm always running superclean supernew oil in my shiny camaro. Its shiny on the outside, and shiny on the inside, and thats the way I like it.
. Clean, good, like-new oil is a comfort to me when driving my Camaro in the summer heat and thats that.
Tell me patman, what is so GOOD about changing the oil less often? How much money am I really going to SAVE?
Say I drive 15,000miles per year. Say an oil change costs me $20 in components.
Oil Change Chart:
Every 3,000 = $100/annually
Every 5,000 = $60/annually
Every 7,500 = $40/annually
So I save $60 max a year? Whats that...1-3 hours of labor at my job? And what if the oil costs more - do I really save anything at all? What benefits do I get for changing it LESS often besides possibly cost? BFD I say - its not enough for me to worry about. The 3,000 mile "hassle" I enjoy, and it gives me a chance to inspect my car head to toe.
Where do you get the numbers for 10 microns for the Mobil 1??quote:
Originally posted by Patman:
I honestly don't think the 10 micron and smaller particles cause as much wear as we've been led to believe. Even Terry admits that he hasn't seen much difference on the oil analysis results with people using a 10 micron filter like the Mobil 1, compared to a 25 micron filter like the AC Delco.
Thinking about this, maybe its not the wear you should worry about, but by filtering smaller microns, which would also include, soot(some not all) sludge, varnish, moisture, glycol, fuel and other contaminants your oil does not have to work as hard. Therefore the oil can work harder at lubricating and cooling.quote:
I think it might be more critical on an engine with very small clearances, but I think most engines out there have large enough clearances that most 15-20 micron particles can pass through the engine without doing any harm.
I think the Mobil 1 website mentions it's a 10 micron filter, but it's also mentioned here too:quote:
I just don't see a full flow filter that will have enough flow to filter at 10 microns and still keep enough oil going to the engine.[/QB]
Here is the datasheet on the mobil 1 filter: http://www.mobil.com/mobil_productdata/automotive/transmission/oilfilterpds_content.ht mlquote:
http://www.shoclub.com/lubrication-oil/lubrication-oilpart6.htm
excerpt:
One other thing I learned is the media in a Mobil 1 filter only looks the same as a K&N oil filter media. The Mobil 1 filter has much higher synthetic fiber content designed to filter down to 10 micron while the K&N is designed for "more sporting" applications and filters down to only 20 microns. The Mobil 1 is focused on deep cleaning while the K&N is optimized for higher flow.
DISCLAIMER:
The author is neither a professional engineer nor member of the Society of Automotive Engineers. Therefore any opinions expressed are not professionally held and should not hold any more weight than any another fellows uneducated opinion.
[ July 30, 2002, 11:40 AM: Message edited by: msparks ]
