Brake related vibration
Originally Posted By: ram_man
Hopefully I type this correctly
Driver front rotor had a runout measurement of .003
Passenger was .0012
So I’m wondering if the passenger front is my issue
No, it would be the other way around, you have more runout (close to 3x) on the driver front based on the above numbers unless you missed a 0.
Passenger was .0012
I did should read 0.0003
Passenger was .0012
I can believe those numbers. Runout itself does not cause pulsation issues with a floating caliper, DTV is what causes pulsation. Excessive runout will cause DTV over a short period of time.
You need to either machine the rotors on-car or replace the rotor and get runout down to a more reasonable level. .001" or less is what you should be aiming for.
