Brake flush on '18 VW Atlas
Virginia
Knocked out the 3 year brake fluid flush on our '18 VW Atlas. Easy job took about an hour. Used 1L of ATE 200 fluid.
Pretty sure the VW 501.14 brake fluid spec consists of a DOT 4 LV fluid. SL6 may have been a better (and cheaper) choice than TYP200.
$15 for a L plus higher temp so I'd call it fine - the SL.6 was $5 less and is a more daily fluid it looks like. Yes the spec is a lower temp I believe. I run the Motul RBF 600 in my Golf. I'll just need to do the flush more frequently with it I suppose.
I thought some old fluid stays in the ABS pump?
Unless you cycle it during your flush.
No idea, this is the typical way I've "flushed" brakes - just push the fluid though until the color changes. It's good enough and serves the purpose. I don't know anyone that does the ABS thing unless they get air in there which would only happen if you let the reservoir/bleeder tool empty.
The fluid's boiling point is not the issue. The issue is related to fluid flow at low temperatures or the overall viscosity curve. DOT4LV is significantly less viscous than DOT4 at low temperatures and allows for more ABS functionality. VAG is not the only OEM that has moved past "regular" DOT4 and onto DOT4LV for these reasons.
The ABS seemed to work just fine when I gave it a few 60 to zero panic stops yesterday to try it out. I run the Motul stuff on my Sportwagen with no issue but your comment is noted.
Under "most" driving conditions it is a non-issue. But technically there is a difference in viscosity and can affect operational characteristics under very low temp conditions.
TYP200:
Product properties:
Condition Homogenous, transparent
Color yellow
Boiling point min. 280° C/536° F
Wet boiling point min. 198° C/388,4° F
Viscosity at –40° C/–40° F max. 1,400 mm²/s
Viscosity at +100° C/212° F 2.2 to 2.8 mm²/s
Water content max. 0.20%
https://www.ate-brakes.com/media/2322/ate_td006_dot4-typ200-web.pdf
SL6 (DOT4 LV):
Product properties: Condition Homogenous, transparent
Color yellow Boiling point min. 265° C/509° F
Wet boiling point min. 175° C/347° F
Viscosity at –40° C/–40° F max. 700 mm²/s
Viscosity at +100° C/212° F 1.7 to 2.3 mm²/s
https://www.ate-brakes.com/media/2320/ate_td007_dot4-sl6-web.pdf
