- Joined
- Jan 3, 2026
- Messages
- 7
2015 1.8T US Passat 5 Speed. The car has a bit over 100k on it. I'm looking to change my brake and transmission fluid, it's never been changed. I'm planning on using TRIAX MT 75W-90 GL-4 for the transmission. Thoughts?
As far as the brake fluid goes, I'm aware of how important that choosing a good brake fluid is. I don't think it's been changed in a few years. After a bit of heavy braking, I get brake fade quickly. I also know that the brake fluid is used for the clutch actuation, and for the traction control system, via the ABS module. I have read that using improper fluid (DOT4, but not to VW spec), can cause slower ABS module reaction times. I'm thinking of using ATE Typ 200, can this improve brake and clutch feel?
