Turkey basters do not put air into the fluid. Its just a method of siphoning and refilling the reservoir. This is a great way to remove moisture and refresh the fluid. It is NOT a substitute for bleeding and was never meant to be. And, if the master cylinder is always kept clean, bleeds are quicker.
In the real world, I'd rather see brake fluid bled every year. 2 years isn't all that bad. Maintenance isn't feasible anymore since we're lazy, cheap, and busy.
It also must be bled at all brake services.
Bleed method is for the owner to decide. Speedbleeders, 1 man bleeder hoses/bags, pressure bleeders, and vacuum bleeders, are available. But, learn your vehicle since not every vehicle tolerates all methods. Certain automakers also turn ABS into a hassle.
