The master cylinder is not usually damaged when the system is open and the pedal pushed to the floor, but conventional wisdom says that it could happen.
My '96 Volvo with ATE brakes required bleeding in a sequence starting at the closest wheel to the m/c and working away. I don't know why, but it worked well.
Use a six point socket or a five-sided tubing wrench on the bleed nipple to break it loose. Soak the threads in penetrating oil first. DO NOT BREAK THE NIPPLE, or you'll have a much bigger job on your hands. A 12-point wrench is likely to round off the bleed nipple flats if it is tight. After the bleed nipple is loosened and lightly re-tightened, put a good smear of grease or pipe thread compound around the threads before you do the vacuum bleed to keep air from being sucked in around the threads.
Brake fluid is corrosive--keep it off painted surfaces. Do not let your master cylinder run dry while you're bleeding, or you'll have a much bigger job.
