Gravity bleeding of brakes ...
Quote:
I drain it dry.
This is exactly why one shouldn't believe everything one reads on a website, even one as otherwise reputable as BITOG. Now some kid is going to think that this is OK, get air in their brake lines, and kill themselves. All thanks to A-U relating the dumb luck he's had until now...
Quote:
Quote:
I drain it dry.
I know it hard but...don't be an idiot.
I saw earlier in the thread that someone drains (or vacs) the old fluid out of the master cylinder, doesn't that introduce air? or can you vac out resvor safely??
Its just a reservoir sump. As long as you don't pump the brake pedal with no fluid in the reservoir, you can siphon it out and refill as needed. No air is introduced via a reservoir siphon/refill which should be done prior to starting any bleed.
