- Joined
- Apr 8, 2022
- Messages
- 36
Blue print ADH22114 oil filter.This is a honda spec filter ,oem reference number 15400-RBA-F01. Blue Print is a subcompany of febi billstein.
This one has a real silicone ADBV ( white soot on the burn test),lots of pleats (65) and decent filter media .50mm x 1490mm= 745cm² .I also contacted Blue Print and asked if they give out the ISO 4548-12 test results for the efficiency rating.
The canister has a wall thickness of 0.6mm,and the gasket is prelubed.Filter media seems different then the other ones but not sure what it is.
The filter itself is very clean no glue residue anywhere ,and was glued togheter strong.Overal very nice filter specially since i can get them from 1 specific online shop for only 2.37euro or 2.6$ a piece.Other places charge around 5€ -12euro ( 6$-13$).
This might be the filter i'm going to use.
