Originally posted by Ray H:
As long as a larger size filter's bypass pressure is the same or very close to that of the specified size filter, flow rate and pressure will not be adversely affected. Flow rate could even be enhanced. The main considerations in going to an oversize filter are that the gasket diameter and its x-section width be the same, or nearly so, that the exit port size and thread pitch be the same, and that the alternate size filter have adequate physical clearance from nearby objects on the engine, the frame, the suspension system, exhaust system pieces, and/or ground clearance. The advantages of a larger filter, if feasible in a given circumstance, are the presumed greater filtration medium area (usually, but not always the case), higher capacity for contaminent retention (and, by logical extension, reduced incidence of bypass operation), and the nominally increased oil volume that can be carried. (In my case the extra 1/4 quart allows me to fill to a full five quarts - I hate futzing with a partial bottle!)
