I understand,Gary.quote:
Originally posted by Gary Allan:
Colt
What BillinUtah is saying is that if the OEM spec filter for your model (even if the same engine in another application gets the bigger filter) isn't on there ..and you run into troubles ..then you've provided one avenue of "escape" for the dealer. It's the same thing in an argument with a spouse. You don't have to be "wrong" or at fault ..just provide something to beeach about ..and you've lost and have to then fight to get it straightened out. You're put on the defensive.
Personally I wouldn't worry about it. Just kinda keep it in mind in the back of your head that if anything goes whacky with your engine ..spin off the long one ..and replace it with the correct one.
Here's the way it would play out. Your engines seizes. It's towed in. The tech sees a bigger filter on there (which he should know ..since he works on them all the time). He calls over the service manager and shows him that the oil is full ..but the filter is not the correct part #. The service manager then quotes countless mythical incidents of engine failures due to improper filter selection by the owner ..and attempts to deny the warranty claim. The onus would then, by default, be upon you to prove that the filter could have nothing to do with the failure. Not that this would be too hard ..but now you're the one doing the proving.
That said, the likelyhood of an engine/lubrication related problem is very slim. I would use the larger filter and not worry.
Will keep a Toyota filter on hand just in case.
The Corolla filter location is great.Right in front of the engine and vertical.
