Fram is a crap filter tho.quote:
Originally posted by labman:
The Fram PH 3950 is the same size on the outside as an AC PF 1177, but only has 1/3 as much media. I like facts and data to make my decisions on.
I'm here to learn,labman.
Do a cross-reference to the Purolator L14477.quote:
Colt:
.... This tiny filter has me concerned.
On my Grand Prix I use a 4.3L chevy filter which is bigger than the stock GP filter.
Is there a bigger filter I can use on the wife's Corolla?
http://www.a1lubricants.com/ofrefer.htmlquote:
Originally posted by Points:
I use FL400 on my 2004 Vibe with a Toy. 1.8L. Perfect fit.
Thanks for the reply.quote:
Originally posted by TC:
"This tiny filter has me concerned."
Something to keep in mind is that at least some (if not many) of the small Japanese OEM filters actually have a surprisingly large media area. And that's what's important -- total media area. Some filters with medium or large shells actually have a modest amount of media -- the Bosch #3312 filter for Hondas is one example. There's at least one Subaru OEM filter which is said to be tiny, yet has a large media area.
I do know that if one doesn't know the area for a given filter, but they're concerned about same, Purolator PureOne and Wix/Napa Gold filters, in general, have more media than most. This claim comes from the numerous filter studies I've read, plus a bunch of e-mail inquiries to the various manufacturers. There's certainly other good brands as well, but if you go with PureOne or W/NG, it's unlikely you'll need to give much thought to media area or filter capacity.
Very interesting...thanks!quote:
Originally posted by Gary Allan:
Colt
I'm of the opinion that the bypass valves are there to protect the media. Assuming that you're comparing WIX/NG to WIX/NG in a bigger can, you can reasonably assume that the bigger can will have higher holding capacity.
Although we can reasonably assume that the bypass valve is there to protect the media, we don't necessarily know why a manufacturer would spec a given filter for a given engine ..nor why if you get a WIX it may have 8-12 bypass valve setting ..while a Baldwin may have a 12-17. One could reason ..that since even x-ref filters have different bypass settings between them ..that they have less to do with the engine that they're used in ..and more to do with the filter itself. Assuming that the bypass valve setting wasn't something radical like some VW/AUDI with 30 psid ratings ..I would not give it too much thought.
I'd go as big as you can in the finest filtration level available.
Amsoil's SDF57 will fit the Corolla engine. It has the same threads, but a little larger gasket diameter.quote:
Originally posted by PulMax:
Does Amsoil make a version of the 90915-YZZA1? Thats bigger, but would fit.
I called Amsoil and the rep said there isn't a larger filter he could recommend.quote:
Yes, essentially. They are where they are at for the protection of the media ..or so I reason. It's like a question of horses having one type of tooth ..and cows another ..yet both survive on the same grassquote:
Or do you mean that by-pass numbers are almost irrelevant?
Thanks,Garyquote:
If you're intent on Amsoil ..plug in
L14477
B37
51396
and see what it pukes out.
All of these filters are what all these filter manufacturers offer for this installation. That is, they are 8-11 bypass settings for WIX ..they are 14-18 for Purolator ...(the L14476 is the same as the b33 and 51394 in Baldwin and WIX and has the same 14-18 bpv setting).
Do you see what I'm getting at here??
So it is the M-103!quote:
The WIX site says that the M1103 is the 51396![]()
You'll really be SOL *if* you have to have any warrenty work done with anything other than than what Toyota or the mfg of the filter states what should be on there.quote:
We are both SOL and are relagated to small filters!
