Big-block engines
JHZR2
Staff member
New Jersey
Was next to an old chevy C/50 (I think from the early-mid 1970s) today, and it had a 366 badge on it. Got into reading up on the 366, as it is an engine I hadnt heard of.
But my one question is this - what designates a big block v8 from a small block? For example, GM made a 348 big block v8 that apparently sold, even in cars, alongside the small block 350. What's the difference?
Could I make a 6, 7 or 8L V8 that is not a big block? For example, the old 366 was a big block. Is the 6.0L vortec truck engine a big block? What about the upsize V8 engines used in the vette Z06?
Similarly, GM made some giant V6 engines for medium duty trucks back in the 60s. Are they considered big block, small block, or because they are V6, do they get neither designation?
Thanks!
GMC even hooked 2 V6s together and had a V12! The 366 was a long lived engine.It was usually standard equipment or optional above the 350 in some apps for a number of years.
This is my understanding ... I could be speaking out of my rear end here but I actually came pretty close to buying an old 427 (not original) suburban and did some research on the engines available.
The 366 is a "Tall deck" big block - it has a taller deck and bigger cylinder heads. There are two engines in that "family" - 366 and 427. The 427 tall deck big block is not related to the other 427 big blocks and really has no performance aftermarket. They also aren't directly related to any of the other "big blocks" out there - 454.
GM had some big V6s for a while, but I don't think I've ever heard them referred to as "big block" or "small block" ... they're just really torquey V6s.
The difference in "big block" and "small block" with GM is ... the block and castings. It really is a GM term. IE - Ford Windsor and Cleveland V8s. The 302, 305, 307, 350, 400 (I'm sure I am missing some ...) are all similar wheras the big blocks 396 402 454 427 (not tall deck) were all related.
It's a name for an engine family pretty much.
The 366 and 427s had forged internals and were made for severely overloaded gas powered dump trucks, etc that would be run all day with the drivers foot to the floor at red line.
I think for Chevy, there was a small V8 block and a large V8 block. I assume the major difference is bore spacing.
Anyways I think a small block can get up to something like 427 cubic inches with the largest bores and longest stroke crank that will fit.
And I don't know what the practical limit is for a big block but like you found, they did make several smaller displacement big blocks. I guess for stuff like dump trucks, you'd rather have 400 ci BB that could be held WO for hours than a bored to the max small block.
I think all recent chevy V8's are small blocks in the Vette's and 1/2 to 1 ton pickups. The old 454SS pickup was a big block.
I remember in shop class that a big block motor on an engine stand was a BIG lump of metal, and the small blocks were quite small in comparison.
The difference is usually the deck height. The deck height increase allows for longer strokes. Taking Oldsmobile for example, all of the Olds small blocks had 3.385" strokes, and most of the Olds big blocks had 4.25" strokes.
In the end, you had very oversquare small blocks (like the 403 ci, at 4.351x3.385), and undersquare big blocks (like the 400 ci, at 3.8706x4.250).
There is no official distinction between big blocks or small blocks. They are relative terms. These terms were informally coined during the muscle car era. I'm pretty sure they represent the two different classes of base castings from which different engines were made within each company at the time.
I've also heard "big" and "small" applied to various 4-cylinder engine families, within the same manufacturer. And the 2.0L point is usually the cross-over. "Small blocks" are sometimes used to describe a smaller engine casting used for 1.6/1.8/2.0L engine family, where a "big block" might describe a larger engine casting for a 2.4/2.5/2.7L engine family.
This is even more informal than the domestic V-8 connotations, but I've read in more than one place that Honda's K-series engine is Honda's "big block" 4-cylinder engine, whereas their R-series engine is their "small block" 4-cylinder engine. There is an R20, but that's as big as an R-series goes. And there is a K20, but that's as small as a K-series goes.
I have not yet heard of V-6 engines being called either large or small.
For GM engines, the physical block size is different. For example, large block/small block 427 Chevy engine:
I get your point with the Cleveland and Windsor. There are still Ford guys arguing over whether the Cleveland is a big block or not because it uses the smaller bell-housing and then there's the whole grey area of the 351M/400. Ford had some problems with measurements. There are two "351s" that actually displace 352 cu-in, but they didn't call them "352s" because that displacement was already being used by the FE 352 (which has it's own unique bell-housing pattern) So, in Ford's line of thinking, it was okay to have 2 "351s" but not 3 "352s". Maybe that's how they made the 302 a "5.0 liter" even though it displaced 4.9 liters.
But nobody really argues over whether a 429/460 is a big block or not.
And then there's Chrysler. 273, 318, 340, 360...etc LAs are small blocks. 383, 413, 440, etc... RBs are big blocks. So it's not really a GM thing.
Thanks!
Chevy's small block had a bore spacing of 4.400" and a deck height of 8.900". The big block Chevy is a 10% upscaling of the small-block, with 4.840" bore spacing and 9.8" deck height. The tall-deck big block had a deck height of 10.2", and was built in 366, 427, and 496 (Vortec 8100) displacements.
The 348 big block was the first of Chevy's big block that sold in 348, 409, and 427 (very few) displacements. These are known as the "W-motors" because the shape of the valve covers resembles a W. This engine was built from '58-'63, and was then redesigned with canted-valve heads to become the big-block Chevy.
You could make a 6 or 7-liter small-block, but my opinion is that traditional small-blocks are stretched too far at 400 cubic inches (6.6 L). The Vortec 6000 is the modern small-block (LS-series, as some call it), and has the same bore spacing of 4.400" as the traditional, but has a taller deck of 9.240". This engine is built up to the 7-liter (4.125" x 4.000") displacement that is the LS7 engine of the C6 Z06 Corvette.
The giant V6, V8, and V12 truck engines that GMC built from '60-'74 were completely different beasts, with bore spacing of 6.500" and deck height of 11.600". The V6 was built in 305, 351, 379, 401, 432, and 478 displacements. The V8 was a 637. The V12 was a 702. I have a 478 V6, and two of the V12's.
The 351C engine has a shorter deck height(9.2") than the 351 Windsor(9.5"), which is no doubt small block...
Hard to say on the 351M & 400, guess those would be best called intermediate blocks...
The 302 referred to as 4.9??? Naahhh that just ain't cool, besides Ford had a 4.9L engine in the 300 I6...
For the little known, the Ford FE 427 actual displacement is 425cu in(424.965), and the 428 is 427cu in(426.544)...
Don't forget the Ford Big Block Six banger which was 300 cid (4.9L). Not sure Ford ever called it a big block but fans of that engine do. Chevy had a 292 cid six banger in pickups that may also have been big block compared to their other sixes.
Not related to the thread, but I once calculated the displacement of the Mustang 302 pushrod V8 that was commonly called a 5.0 and it rounds to 4.9. Obviously 5.0 sounds a lot better for a performance car.
Oh and International Scout had a couple 4 bangers, one of which was half of a 392 V8 or 196 cid, which to me is a big block 4 banger. (think I got the cid right, may be off by a couple inches)
Thanks!
There's really no consistent differentiator. Back when the term "big block" and "small block" came into use, each of the manufacturers typically had a distincly different block casting for the larger engines than the smaller ones. Mopar had the "LA" series smallblocks (273, 318, 340, 360), the "B" series low-block bigblocks (350, 361, 383) and the "RB" series raised-block bigblocks (413, 426, 440, and an early 2-year only 383). The raised blocks accomodated longer strokes. The Chevy side had the venerable smallblock, and then both the "W head" (348/409) and "Rat" (396, 427, 454) big blocks. Ford had the "Windsor" smallblocks (289, 302, 351, etc.) and then several big-block families including the "FE" aka "Y-block" engines (390,427, 428, etc) and the later "Lima" 370/429/460.Then there were the "Cleveland" engines which related mainly to head design, but the "modified" Cleveland also included a raised deck compared to a Windsor IIRC. Cadillac never really had anything you could call a "small" block until the 80s. Olds had what were called "big" and "small" blocks, but they really only differed in deck height like the "B" vs "RB" Mopars did and both those were considered big blocks because of the bore size.
When you get right down to it, its arbitrary. In GENERAL, though, I'd say that for the most part anything where the block is long enough to support a cylinder bore of over 4" is a big-block, anything with a bore under 4" is a smallblock. But you can immediately find exceptions like the Mopar 340 (bore 4.04") which is still a smallblock because its based on the LA block that started out at 273 CID. Similarly there are big-bore smallblock Chevies like the 400 that are still classed as smallblocks because the block heads and casting derive from the the smallblock, not the "Rat."
Tracing the roots and lineage of today's engines back, you can make the claim (and support it) that big bores notwithstanding, none of the Big 3 still make a big-block at all. The GM LS clearly derives from the SBC, Mopar's 4.7 isn't related back to anything but has nearly the same bore center spacing and exactly the same conrod length as the LAs and is physically small. Same for the 5.7 and "392" Hemis. And the Ford modulars are also physically small and light compared to the old Lima engines.
Now all that's the factual stuff... but I have to say that there's just some intangible difference, too. Since all factory development on big-blocks stopped in the 70s and 80s, even the most refined of them are a bit rough around the edges. They're loud, they're violent, they have more torque than a small planet spinning on its axis, they're thirsty, and they pollute. But boy are they FUN!
Big blocks are more beefy.
A lot of small blocks put out the power but don't have the beef, so when their in a high stress application like a boat, they don't last as long.
Oh yeah. That may actually be bigger than Porsche's 968 3.0 4 cylinder.
as far as the V6es, I always considered the 90° V6es to be the "big blocks" and the 60° V6es to be the "small blocks". But they are not really. Some of the 60° V6es are as big/bigger than the 90°s (ie: Cologne 4.0 and Hyundai Lambda 3.8) and the 90° V6es are usually just pared down small block V8s
I'd agree with you IF you'd said 4" stroke but defiantly not 4" bore... Even the miniscule Ford 5.0 small block with 8.2" deck height will support a 4.04 bore but you'll play [censored] getting more than a 3.4" crank inside one of those, that with a .030 overbore produces a 347 ...
Motown 454 has a 4.25 bore but it's considered a "Small Block Chevy"
